How do you chamfer a tapped hole?
FigureItOut
Bentonville AR
Building a vise mount at the moment, but every time I'm putting something together and tapping holes into thick plate or whatever, assembly is a lot more difficult than with manufactured parts. I'm pretty sure that lacking a chamfer is my problem. How does one put that nice little bevel around the top of a tapped hole to help guide the bolt in and get it started?
Thumper68
Duluth MN
The easiest way is to use a countersink.
ae235
A_Pmech
IL
A one-flute countersink to both sides of your hole before tapping will remove any burrs due to drilling the hole and make starting the tap easier.
A burr-free threaded hole is an easy to assemble threaded hole. :)
F
FigureItOut
Bentonville AR
So, countersink before tapping, got it. Is there a rule of thumb on what size countersink? I can pick up countersinks for my common sizes, if I tap something don't have a countersink for, is there a reasonable substitute? I most often tap 6-32, 8-32, 1/4-20 and 3/8-16.
rbgearz
Illinois
When I'm feeling lazy and don't want to look for a countersink I just hit it with a bigger drill bit. Not the right way but gets the job done.
F
FigureItOut
Bentonville AR
I try that, and get terrible results. The bit tends to bite in and mangle my hole. I'm using 135° split point. I buggered up a piece this evening trying that method, which prompted the question. I worked the holes with a file a bit and it may be salvageable, but that really doesn't work out well for me at all.
Thumper68
Duluth MN
you should only need a few sizes to cover your common holes.
6PTsocket
Unless you are planning to drop a screw head below the surface, any countersink that is bigger than the hole will do. We are talking about just chamferring , right ? Countersinking a screw head involves matching the angle of the screw head . There are 82, 90 and even 115 (or was it 110?)degree countersinks.
6PTsocket
Been there,done that and I'm sure we are not the only ones.
matt_i
SE Michigan
A 135 deg point doesn't follow a pilot hole very well, the 118 deg points work a lot better for this.
I have very good luck with MA Ford or Melin Tools 2+2 design. You can run it at about 10 rpm in a cordless drill and it will deburr very nicely.
rlitman
Long Island
Well, the countersink needs to be bigger than the hole. A huge countersink will still work on small holes, but is expensive, and might interfere in tight spaces. Small countersinks are cheap if you burn them up.
BD1
north side
Typically the countersink pitch or bevel matches what a flathead bolt has on it below the head for a flush gripping connection.
astroracer
Mid_Michigan
Standard machine shop practice for a drilled and tapped hole is the chamfer is added after the drilled hole and it should be at least as big as the "final" bolt size.
Example: a 1/4-20 tap uses a .21 diameter tap drill. The chamfer should be at least .25 diameter to get a good start with the tap. Can it be a bit bigger? Sure, I will usually go about .030 bigger and this pretty much guarantees no high spots or burrs after tapping.
Mark
Dr Stan
Owensboro, KY
I've used the center drill method for years. However since the introduction of spotting drills I rather use them. Since they are 90 degrees .025 difference in depth is .050 larger on the diameter. Fairly easy to calculate how much more you need to go.
joel63
Central FL
Thanks, I learned something about drills.
I don't think I ever heard of them. :thumbup:
matt_i
SE Michigan
A spot drill is the tool you really want in a milling machine to make sure your hole starts where you have fixtured it instead of being worried about drill-bend. The ones I have are all 120deg included to conically pilot a 118deg included drill bit. Also they are all solid carbide which has a higher Young's modulus than steel to further resist deflection.
