Electric Razor Scooter to 2-stroke Project
Markfothebeast
I picked up a free electric Razor scooter that I figured I could at least use the batteries and electric 24v motor from. Than I decided I could maybe have a little fun and use an old 2-stroke weed whip engine and add three 13" Harbor Freight wheels. I haven't quite decided where I'm going to go from here as far as the drive axle and clutch. Do you think that 2-stroke is powerful enough? a076955af14b4422734443d4f4c2a207.jpg
kbs2244
I would guess you will need to gear it down.
It will not be a speed demon.
Markfothebeast
Yeah. It's still just a scooter so you can bail at anytime, unlike the Honda.
Sent from my SM-G920V using Tapatalk
racingtadpole
The far side of crazy.. but sometimes Australia
The weed eater motor should be powerful enough if you give it a rolling start to help it. No problem there its a scooter.
I would adapt a roller blade type wheel onto the output shaft of the motor, locked solid to the shaft. Then sit the whole thing on a spring loaded hinged platform above one of the rear wheels. Put another brake lever and cable on the handle bars, and use it to pull the assembly down so the roller blade wheel contacts the tyre to drive it.
Gets you a clutch and drive mechanism and a bit of reduction all in one assembly.
ilovevocs
Toledo, Ohio
I would widen the deck. The goped has a wider deck and I find it much more enjoyable to ride for a grown man.
You better do some downhill testing before you power it. With the two wheels in the rear you may find the front end configuration less than desirable.
zkling
You are going to want a more torque motor than that with those wheels.
gungatim
west mich
one of the easier ways guys have been building those over on the motorized bike forum is with a BMX foot peg to drive the wheel directly. you can adapt the output shaft to one of those -- get one that is knurled...you need to do the calcs for the engine RPM range to diameter of drive to driven wheels. you may need a jackshaft setup. chainsaw motors are more popular since they have more power and a clutch; generally easier to adapt.
Todd.Brock
Cincinnati
I would probably use a left over 5 hp Honda motor :)
This looks like fun. Which I had the time! Keep us updates
Markfothebeast
Thanks guys (and gals). Lots of good ideas here. I think I'll go the 4-wheel route and raise the ground clearance for rough terrain being that I live in a country area. It will need a wider platform as mentioned. I'll take the old batteries and separate them from 24v in to 12v and run an LED fog lamp on the front.
I picked up a free Trek mountain bike with a bent fork that I can possibly use for parts. Or even use the frame if I can weld it with a stick welder. Not sure if it is Chromoly(?) or aluminum.
texasranger
Maryland
I'd think you will be better off going to 2 wheels versus 4. Less weight, less rolling resistance, and you can lean it into a turn rather than pucker. Like others have said, drive the tire directly with the motor on a spring loaded mount. Add a plate so you just push it down with your foot to make the motor contact the rear tire.
gungatim
west mich
you can always braze it, that is how many bikes are/were put together.
here's a little scooter I built using a kids bike fork and some angle iron, and a 2-stroke toro snowblower engine for inspiration. does almost 30mph...
ilovevocs
Toledo, Ohio
Here's my go-ped next to a razor 300 to give you an idea of the size difference.
If you want some rough dimensions let me know.
