kctyphoon
For purposes of people google searching Neiko 40447A is the model #
So listen people, if you want some good advice - STOP BUYING THE HF UNDERHOOD LIGHT.. just stop.. I never understood why the HF gets good reviews, cause the $35 small Capri tools light is less than half the size, and much brighter. I assume if you have nothing, then yes ANYTHING is better, but you have a much better option now.
I just bought this new Neiko myself.. It is almost EXACTLY a longer version of the small LED stick light, but the LED's are slightly larger. 2 light settings, the low is about twice as bright as the smaller version on its single light setting. For anyone that already owns the small model (like myself) you guys know how good it is.. this model is that same light on steroids..
1200 lumen, 600 lumen settings. 8,000mah Lithium Ion battery. Works both corded and cordless.. 6hr and 3hr runtimes. the lens / light wand is slightly flexible, so this thing won't break if you drop it.. it's very lightweight, literally just a long thin LED board inside a plastic tube. Comes with a 2 sided spring loaded underhood clamp, and 2 magnetics for mounting the detached light on a metal surface. The light is obviously detachable from the mount, and can used under the car as well.. the hex shaped handles keep it from rolling..
To be fair, this is probably NOT like a $200 professional underhood light.. if I had to guess, the mount is probably kinda cheap compared to what you'd find on a pro model. That said, the previous small version of Neiko/Capri tools led light is way better then the full HF model of underhood light in terms of brightness. Again, the new Neiko is almost twice as bright as the small model just on the LOW setting, and you're getting the hood clamp.. if it's not clear, I own the HF model, the small Capri tools light, and now this one too. So this isn't conjecture, I'm just telling you how it is..
Now for the price.. the ABSOLUTE cheapest I've found this for is $69 shipped on eBay. There are also 2 listings on Amazon, one for $72 shipped from a 3rd party seller, and one for $79 shipped direct from Amazon. I chose the $79 option just cause I had a gift card and would rather deal just with Amazon. I will post links below.. if you wanted a cheap cordless option that was still good, then this might be a good option for you... you can buy BOTH Neiko models from Amazon for $107 shipped.. I recommend both models..
$69 eBay listing - http://pages.ebay.com/link/?nav=item.view&alt=web&id=252727646033
$72 Amazon listing - Cordless Mechanic Light Rechargeable Utility Light With Hooks (EXTRA LONG) https://www.amazon.com/dp/B01M360ZXO/?tag=atomicindus08-20
$79 Amazon listing - Neiko 40447A Rechargeable Underhood Work Light | 202 SMD LED Bulbs | 1,200 Lumens Max Brightness | 8,000 mAh Li-ion Battery | 2 Brightness Modes https://www.amazon.com/dp/B01MTXC016/?tag=atomicindus08-20
$35 original Neiko/Capri Tools model - Neiko 40464A Cordless LED Work Light, 350 Lumens, 5 Hours Run Time, 4,000 mAh Rechargeable Li-ion Battery, Multi Purpose https://www.amazon.com/dp/B00WI9585I/?tag=atomicindus08-20
