The copper unions I bought from Lowe's doesn't doesn't hold air 150psi no matter how much I tighten them.
Do you guys recommend putting rectorseal or some other sealer. I don't really care if it is semi permanent. I already took them apart once to move so probably they don't work as well now. But a couple of ends at the reel and the compressor are already soldered on there so it is not easy to replace.
If I seal the threads does that also seal off air that escape past the mating service.
You used to get nice heavy cast bronze ones from Mueller or Nibco that sealed very well, but no more.
