Retractable Electrical Cord - Anything I Should Avoid?
TOYSTRY
San Diego, CA
I've read all the post related but nothing specifically stated what to avoid, just what people bought. With that, there doesn't seem to be a profound backing of any brand either.
From my research it appears that the big ticket items are:
- springs failing
- gauge of cord
- length of cord
- amperage of cord
- number of plugs on cord (single/triple)
- retracts easily without fuss
Right now I'm looking at the 40ft harbor freight version since it's a heavier gauge, 50 ft and HF offers 20% discount.
Not concerned about the price, just want something reliable without a bunch of fussing with it.
http://m.harborfreight.com/40-ft-retractable-cord-reel-with-triple-tap-62952.html
Z2V
Cedar Park (Austin) Texas
I'm also in the market for a cord real. I found this one the other day. I requested a price quote, should have been my first clue, and fell out of my chair when I received the quote.
25 ft, 12/3. Made in USA
$585.62 plus shipping
Is cost an issue?
All BS aside, I wouldn't settle for less than 12/3 wire, 25-30 ft length. There are many out there but it seems the majority are plastic housings. I'd much rather have a metal case.
Good luck in your search.
T
TOYSTRY
San Diego, CA
Is cost an issue?
Ok maybe price is a concern lol. At $585, that's a brand new table saw that I'd get more use out of.
eastbaysubaru
NorCal
I've had this metal-housed one for almost ten years and it's been great.
http://www.sears.com/craftsman-cord-reel-retractable-with-30-ft-extension/p-03483928000P
I haven't run into any issues with it being 16 gauge but you could step up to 14 gauge if that was a concern.
http://www.sears.com/craftsman-30-ft-cord-reel/p-03483929000P?rrec=true
I know you're looking for 12 gauge but these are pretty close and are a hell of a lot cheaper than that $600 reel Z2V mentioned (I was more than slightly thrown off by that price).
-Brian
Sh40674
Iowa
not retractable.. gotta wind it.. but you could pick your cord (as long as you're mounting on the wall) i was actually looking for one for my wall... think i'm gonna get this.
Sh40674
Iowa
otherwise flexzilla makes one.. around 100 bucks, 14 gauge but has great reviews
Sh40674
Iowa
actually looking at your harbor freight one... only 7 reviews but they're good. you have 90 days to take it back if you hate it.. harbor freight is easy to return things to
JimH74
South Central Texas
I bought the 40 ft 12/3 retractable from Northern Tool. Frequently on sale for 69. They also have coupons, but I've not seen one for a while. Downside is that it has a plastic case. Doesn't get heavy usage, but does what I need it for. Best price I could find at the time. Definitely get at least 12/3 for your heavier power tools.
holt2ton
Michigan USA
LS6 Tommy
Northern NJ
I am lucky enough to have been given a Coxreels E-Z Coil 50', 12/3 quad for free. List on that bad boy is around $550.00. My only complaint is that the rewind tension could be better. IDK if the springs are worn or if it's just the nature of the E-Z Coil's safety system.
Tommy
Farmall450
Marengo, Illinois
I'd be wary of the triple with a reset able fuse built in.
Ours got to the point it would no longer reset, so I chopped it off and put a single female outlet on instead.
While it was nice having more than one an angle grinder would pop the old one...
stang2007
Lincoln CA
What do you intend to run off it, a trouble light, or something small, the HF 50ft will be awesome and give you more money to spend on something else. i have the Costco ""snap on"" it was $30 and came with a light, will handle any of the light stuff i ask of it.
then again if you are running tools (like a grinder) off it it may be a good idea to spend the $$$
all depends on use.
jahn
Hell, Michigan (Pinckney)
I've got (3) of these
https://www.lowes.com/pd/Bayco-30-ft-3-Outlet-Metal-Retractable-Cord-Organizer/1233131
I have one outside near the lake for a bubbler at end of ice season and for battery charging. Metal color is fading
Another on just inside the garage for my powered blower & snow thrower, I change the triple to a single. Cord in PVC and have a few broken sections due to the cold weather.
Last one at bench and works great for my needs
Price was right, thought about trying to rewire to a SJO cable
theoldwizard1
SE MI
IMHO, you want cord with insulation rated at at least SJOOW. SOOW is heavier and should last longer.
-Brent-
Utah
I have a CoxReel hose/cord combo. Yes, they're a pretty penny. For me it was a complete splurge after finding a decent deal. A couple things I'm liking about it (save for the price) is that they're in one unit and I could choose what I wanted for cord and an end. I use the cord more than I assumed I would.
If I were to get another cord reel alone, I'd go with the Flexzilla. I have heard good things and the price is decent.
HWgeek
After about 1yr the retraction on the HF stopped latching to keep the cord out unless at a specific angle. First time I dropped the HF unit, the plastic broke and it was done.
The craftsman I have the older red version, dropped multiple times, still works great 10yrs later.
YMMV
Also see the cord reel suggestions or comment thread (189733)
BleedingBlue
Indianapolis
-Brian
I have had the first link for about 5 years with no issues.
nes999
IL
My father has several of these in his in heated/uncooled shop. These work awesome.
Sent from my VS985 4G using Tapatalk
ssdave
Eastern Oregon
I have a 50 foot like z2v referenced. It's a great reel. Even better is that I paid $5 for it at a yard sale. The heavy construction and quality is evident in it; and it works flawlessly. Is it worth the several hundred dollar premium? I don't know as I didn't have to make that decision!
WVBrady
WV
Z2V
WOW!!
What a find. I just don't seem to have that kind of luck. LOL
nh_yota
Seacoast New Hampshire
I think a heavy-gauge cord reel is overkill for a home garage. I mean, how often are you going to be running a full 15-amp tool like a table saw, miter saw or air compressor from a cord reel? Most of your high-amp equipment is going to be stationary and located near a wall outlet. Cord reels are good for portable hand tools like drills, sanders, sawzalls and lights, and they are much easier to maneuver if they aren't thick and heavy.
Newell33
Midwest
I have an older Bayco unit with a built in 15A circuit breaker built into the back. I've tripped the circuit breaker several times over the years. It's mainly been when using a chop saw and cutting metal in the middle of the shop, but I know other tools have done it too. I know the price jumps up a bit if you go bigger than 15A, but if I had to buy one over again I'd spend the extra money. Then you know you're covered.
I had one of these. I overloaded it without thinking, because of the 12 gauge wire, but it has only a 15 amp rating. I could have repaired it, but I couldn't get the two halves together again. They are just held together by friction with the hard plastic strip between the two halves. I just put plugs on the ends and use it as ordinary extension cords now.
I'm on my second one. The first one lasted 4 years or so, then failed to retract, yeah, good luck putting it back together again.
Good unit overall for the money, bought another one a few years ago. :thumbup:
dv8customs
East Texas
I have two of the ceiling mount Roboreels I picked up when my Lowes was clearing them out. I wouldn't pay the full price for one but they have worked very well for me.
One wouldn't power on after a storm but a quick call to customer service had a new one on its way and I returned the defective one once it arrived.
http://roboreel.com/ceiling-mount-buy/
rburke65
Canfield, Ohio
I also have shopped on the Internet for a cord reel and about "dirtied my pants" when I saw the prices. I, at first, thought in was a misprint......ah NO.....it was not.
Sh40674
Iowa
i run my miter saw, shop vac, table saw, circular saw, on cords. i can plug them into the wall but i like to move them out to the center of the garage for more room. i have a 14 gauge cord. never had an issue with either on it. however, none of them run at the same time on one cord. a 14 gauge cord will handle a 14 or 15 amp saw just fine. generally when you use a table saw or miter saw or the like you run it for a short bit, stop it. run it, stop it. if it was continuously running it'd be a different story (like if i was a woodworker or something)
