Pam cooking spray on seat tracks ?
rlitman
Long Island
Definitely NOT cooking spray. That uses cooking oil which will go rancid over time, and will get sticky.
454ragtop
Carver, MA
While not a spray, Door Ease stick lube works awesome for this. The bucket seats in my Grand prix would make a horrible grinding sound when tilted fwd, a little Door Ease and they're smooth and quiet.
G
GophersGarage
Ontario Canada
I know on the vette they say to use de electric type of grease since it is clear. think might go that way about it and be done
ambenz
NW Chicago Suburbs
I always have a can of Liquid Wrench dry lube on the shelve....
CJM8515
Teflon chain lube. I use it on my atv chains and ride in sand, not an ounce of sand sticks.
xjfish
I use "Sil-Glyde" from Napa. Pick your petroleum based shlube, but please don't use cooking spray.
G
GophersGarage
Ontario Canada
I went over to the store and the guy sold me some product called jbweld he says a lot use it for car stuff. its 2 little tubes to mix. I mixed it up and added to tracks all over
but now I find seat hard to move. dont understand
firworks
IL
On an unrelated note, my bundt cakes keep sticking in the pan and just will not release. I tried spraying some liquid wrench in the pan before I put in the batter and while the cake did release it tasted awful and sort of... cancery. Any ideas? Should I just get used to the taste?
G
GophersGarage
Ontario Canada
best get use to the taste . :beer:
rlitman
Long Island
Have you tried white lithium grease. It should taste much better than liquid wrench.
Pam is nothing more than cooking oil in a spray can. Nothing magical about it.
Actually, it contains more than just cooking oil. Yes, it is probably more than 99% cooking oil, but wasp killer spray is 99.5% kerosene, and yet that 0.5% (or less) active ingredient is quite important.
In the case of cooking oil sprays, they contain materials to help disperse the oil. Personally, I'll put some oil on a paper towel, and use that to lubricate a pan.
pstemari
Seattle
Boelube T9 will leave a waxy coating. There's also a Boelube stick lubricant that I use on saw blades.
Sent from my Nexus 6 using Tapatalk
rlitman
Long Island
I use Pedro's Extra Dry Chain Lube on all sorts of things. I've found it cheapest at my local bike shop.
It would probably be good for this, if you can get away with a dry type lubricant. I even use it on my shower curtain rod to make the hooks glide smoother. There, it lasts a month or so.
Moparman390
At least your risk of salmonella will be lower.
unslow1
Illinois
Perfect! You don't want anyone driving it anyway.
