how often to calibrate a split beam tq wrench?
tmcquinn
Cincinnati
I have mine done every 12 months to please the FAA. By then it is usually a little off. I went 24 months once and it was off by a considerable amount. Last time it came back rated for clockwise only but that won't affect anything I use it for.
guy48065
Calibration Lab
Every split-beam I've seen has been clockwise-only. I don't think the internals are symmetrical but honestly I've never tried to check one CCW.
As for "how often" to calibrate: Calibration is done to lower the risk of being inaccurate. If what you do doesn't involve any RISK to you, customers or equipment--then there's no need to ever calibrate.
If all you ever do is wrench on your bicycle, your risk is low; if you wrench on the helicopter that carries the President, you probably ought to get that wrench calibrated at least 2X per year.
(Unless you vote Democrat, of course!)
48548
Phoenix
I use a digital adapter to check the torque, I know that isn't the best but gives some piece of mind.
T45
Send it out for service, you need a higher quality testing device than whatever is lying around the garage. However, you can sanity check it if needed to make sure its not wildly off (potential immediate liability), using a beam (bending beam) wrench with no moving parts. The general rule tho is you multiply the error by a factor of 2, so a 4-5% accuracy beam will give you 8-10% accuracy sanity check. To get at a proper 4% calibration you typically need a 1% testing device.
Stahlwille has some infromation online about calibration process for their split beams. It gives you a sense of what they do at the shop. The short of it is that stahlwilles are much easier to calibrate than other styles of wrench (usually no disassembly and no replacemnt parts), but you still need testing gear and some types of error do require dis-assembly. For other makes and styles you'd probably want correct documentation.
1982fxr
Phoenix
How come there are never huge fights on here when people say split beams are good to go unless they've been damaged? I've read that countless times over the years...
