Removing Rust From Chain.....??
Crow Horse
Southern Tier, NY
I found a long chain (5/16) in the barnyard that was pretty badly rusted. I'm giving it a good soak in a vinegar/salt bath and it's almost finished. I might bring it to work and pressure wash it to remove any other crud. My question, once it's all cleaned up, what's the best and economical way to prevent future rusting, being that any protective coating is gone?
jakemac
New England
A light rust can actually help protect it. Sounds counterproductive, but true.
If the rust gets too bad, drag it behind your truck/car through a sandy area or dirt road until it scrubs itself clean. Then dry and lightly oil it. That's all it needs.
Bare metal will rust faster than metal with a light rust patina.
M6erfan
'Merica!
Back in the day it wasn't uncommon to melt bearing grease in a tub and soak the chain in it. Move the chain around in the melted grease to open up and allow the grease to penetrate in between the links.
Should be GTG
gdocktor3
Connecticut
I think you should hand sand/file each link, then prime it and paint it with rustoleum. Or powder coat. Bright red.
DHCrocks
Hawaii
I don't know how well it works but I just bought some rust block from evapo rust this weekend. My first time using evapo rust and I must say after about 18 hours of soaking my garden tools came out looking great. all the rust was gone. Gave them a light coat of the rust block and after it dried you can tell its there. there is no oily/greasy feel to it. it says the coating lasts upto a year.
http://www.evapo-rust.com/rust-block/
WhiffySpark
That has to be one of the funniest posts I've read from you. I read it 20 minutes ago and still laugh :lol:
Sad thing is this is the perfect forum for someone to actually do that
crguy
SW Washington
Very true. Anybody that has to ask how to clean & preserve a chain is a perfect candidate to take that advice.
rsanter
visalia ca
Send the chain in to have it cadmium plated.
Otherwise use the thing and don't worry about a little rust
Bob
Tom.C
Find the guy from bitchin rides and use his beard thing as a wire brush, that chain will never rust again.
disston
Silver Spring, Md
Carl Sagan, in his work The Demon-Haunted World: Science as a Candle in the Dark said: "There are naive questions, tedious questions, ill-phrased questions, questions put after inadequate self-criticism. But every question is a cry to understand the world. There is no such thing as a dumb question".
From Wikipedia.
nes999
IL
The best way to remove rust on a chain? Buy a new one.
Sent from my VS985 4G using Tapatalk
abachman
Illinois
I put mine in a large plastic bag and sprayed it with Kroil. I closed the bag and rolled it around a bit. Left it sit for a few days and have not had any new rusting.
rick carpenter
Huntsville, East Texas
From Wikipedia.
Who is Carl Sagan?
BDT/NWMN
Erskine, Mn
Put it in a small concrete mixer filled about 1/3 full of gravel. Run the mixer till either the chain is clean, or Your neighbors come over to see what the heck is going on.
If You choose to drag it down a gravel road; borrow Your Mother-In Law's Buick, and wear a wig and bonnet when driving. Be sure to wave at anyone who attempts to flag You down; and avoid backing up.
A_Pmech
IL
Leave it be unless rust is literally flaking off of it in sheets, in which case it belongs in the scrap bin.
Unless this chain is on a ship, I wouldn't be greasing it. A greased chain would be truly miserable to use.
M_George
Eastern Pa.
Drag it around to clean it, put it in a bucket of used motor oil then let drip dry. Gives it a nice black patina.
toolmiser
La Crosse, WI
Heard someone was dragging a chain down the road and someone stopped him and asked "why are you dragging a chain?" Reply was "have you ever tried to push one?"
californiaHank
Ayuh,.... I think anybody who wants a rust-free chain, has waayyy to much time on their hands,....
It doesn't sound so crazy to guys who mess around with boats. Lots of saltwater boats use hot-dip galvanized chain for anchoring. The high-test stuff is expensive as heck, and when it starts to rust, it's a lot cheaper to get it re-galvanized than to replace it.
Mind you, the stuff in the OP's got in his barnyard probably didn't start its life on somebody's gold-plater yacht. :lol:
bushmechanic
Put it in a cement mixer with abucket of sharp crushed stone for an hour....
That's actually precisely how to do it. No different than cleaning certain things or polishing rocks. Be careful when choosing the rocks, and know how your chain was hardened first, though. Fine gravel or "crush and run" make great abrasive media for this sort of rust removal.
Of course, if you have the time and patience, good old fashioned Naval Jelly (or anything of the sort) will knock rust out in a jiffy.
Regardless, after you get rid of the rust, you'll need to protect the chain with some form of oil or grease. There's almost never a reason to throw away a quality chain. Even if you push it beyond it's limits or damage it, you can still use the thing for less critical tasks in the future.
Cleaning up a good one is well worth the effort.
Miss the Pontiacs
Saskatchewan Canada
Give it to a farmer when he is harvesting a stiff stemmed crop. He can drag it behind the combine cleaning it as he goes. This also is great to clean the bottom of a low slung vehicle. Drive backwards to clean it the other way. If you don't want to do the driving find a young person who would you shouldn't have to look to hard. My uncle used to have the cleanest under carriage and we loved doing it.
disston
Silver Spring, Md
Who is Carl Sagan?
He was the guy that had a telescope in his garage. You remember him. Forget what his GJ name was. He collected really old tools.
I speak in the past tense because he passed away a few years ago. A lot of his stuff was kinda boring but when he was on a roll sometimes he could be really fascinating. I think he was the guy that said, "What the mystery is is not if there are other forms of life in the Universe but why they haven't been here before, if you believe that." Or something to that effect.
