tap question
87GN
phila, pa
What's the difference between a plug tap and a taper tap? I need to tap some LS rocker covers, but there is a metal shield below the hole. Or, would a bottom tap be ok to start cutting the thread or use either a plug or taper tap to start and finish with the bottom tap? Thanks.
pstemari
Seattle
taper used for thru hole,use bottom tap
You won't be able to start the threads square with a bottoming tap. Taper taps are the easiest to get going straight, but a plug tap is ok unless you have tough material like stainless. You use a bottoming tap to get the last 5 or 6 threads at the bottom of a blind hole.
Sent from my Nexus 6 using Tapatalk
6PTsocket
There are three types of taps in general use: taper plug and bottoming. It has to do with how many partial starter threads there are before the first full thread. Without looking it up if I am off, the taper has has 5-7, the plug has around 3 or 4 and the bottoming has 2-3. It is always easier to start with a taper and necessary in hard material. Sets that do not give you all three for each size give you a plug tap. I it is a good general pupose tap and has sufficient taper to get you started in most cases. The bottom tap does not have enough taper to start a hole. It's only purpose is to follow the plug tap in a blind hole and cut the last few threads to get thread as close as possible to the bottom. If you need to get almost to the bottom and the metal is not too hard, a plug and bottoming will do you but at that point you might as well by the three piece set of taper plug and bottoming.
87GN
phila, pa
Material is an aluminum LS7 valve cover. I went out and bought a three pack, one of each from amazon. Thanks again.
LumpyMusic
Phoenix Arizona USA
I think those three packs from Amazon (Champion/Irwin brand) are a great way to buy taps. Three GOOD quality taps, all three tapers, for about 20 bucks for the larger sizes. Beats the heck out of the "Every size known to man for $100" sets.
Lump
Fcvapor05
You'd be better off taking the oil shield off of the valve cover.
Tap the hole with that shield in place and you WILL trap a chip (or 10) somewhere, that chip WILL work itself loose and once it does it WILL find a way to sneak into a spot where it could wreck the valvetrain.
Do yourself a favor and do it right the first time.
87GN
phila, pa
shield is riveted to the underside of the rocker cover. Normally I would weld the -10 fitting onto the cover, but these covers have been painted.
leg17
Kentucky
There is a TapMagic product for aluminum.
Otherwise, kerosene is traditional for aluminum.
Matt Irvine
Aussieland!
If you would rather not get a chip left in the bottom oh the hole, pack the flutes of the tap with a heavy grease, it well help retain most of the chips in the flutes.
larry_g
oregon
Another way is to fill the hole with wax. As the tap feeds in the wax will be forced out carrying the chips with it.
lg
no neat sig line
