So Elroy has this fine ole machine. It's a 1978 model or so and has been an oil burner for some time. It's one where you fill the oil and check the gas.
Anyways, today was pick up the leaves day. Put in a good half quart of straight 30 and got the oil well up on the dip stick and went to work. Ran it a good hour. Turned if off several times in the process.
Well went to start it after it had been sitting a good 30 minutes. It lit off fine but it was knocking real good. Just a fast idle and then it went bang and stopped.
Wonder why?
Just in case you're having trouble seeing the problem:
So the question is, What's wrong?? Hope it's obvious
Do we fix it or scrap it?
Wonder why?
