RVA-Jeff
For general Harry Homeowner use? Ripping 1x4? Certainly cutting plywood. Want to save space mainly by getting rid of table saw. Use it 4x a year but need it when you need it.
Who makes the Grizzly track saw?
Depends on your table saw. If your table saw is a 10" or larger then it can cut deeper than a track saw for sure. If it's 8" or so it may be a toss up depending on the saw.
Maybe look at getting a flip over saw to replace the table saw as well as having a track saw, Makita still makes one, the Elu one was very good, the legs come of so it will store away and its other function is a mitre saw, which is better than using a table or track to cross cut (unless very long workpieces or you want to cut part way through.)
We have a track saw at work and we certainly use a table saw a lot less, but its still needed.
I can't imagine unless you just never cut any sheets.I gave away the track saw.
He doesn't use it either.
Space isn't as issue for the average homeowner IMO, if I need to rip a large piece of plywood, adequate space is needed no matter what. Can easily go out the garage or driveway to cut.
Probably grizzly.
Going with the cheapest option isn't usually the best option, but good luck.
Track saws are great for breaking down 4x8 panels, but that is about it.
A table saw excels at cross cuts (even large pieces if you make a cross cut sled) and ripping long, not too wide, stock. Change the blade, they great for dados and rabbets. With the proper jig, they can not be beat for making tenons.
I have also used mine for cutting plastic and aluminum.
I disagree. I have used the Makita, Dewalt, and the older model Festool for reference.unless you have used a REAL track saw it's hard to make a comparison to the guide you reference in your post.
.) Okay, I respect your point of view. Without too much background, I'll respectively disagree. You may reach a point one day where your prospective is altered and then again you may not, until then, good luck with the guides
Don't forget table saws are also great when you need to cut more than 1 of something the same size.Track saws are great for breaking down 4x8 panels, but that is about it.
If you ask Festool, they will say no because they have their own table saw setup. Their tables are tiny and they're designed to rip small stuff.
