Best value R134A manifold gauge
toyotadriver
What do you recommend for a R134A manifold gauge set?
Don't recommend Harbor Freight. Have a set of theirs and only used it twice. Second time it started leaking from somewhere in the body of the gauge set. Not buying another one.
I don't do AC work professionally so don't need the top of the line. I just want something reasonably priced but something that will last.
Thanks.
Ohmthis
Outside of Louisville KY
Look for a cheap/used manifold from yellow jacket. They are rebuildable and you can buy what ever type refrigerant gauge you need to put on it. The hoses from the HF unit might even still be usable for it. I have a manifold that is probably 30 years old that I rebuilt 15 years ago or so and put new gauges on. The key to not killing the valves is to not crank the handle down. It doesn't take much to close the valve. Over-tightening is what tears the seals and then you have leaks.
Trey T
Houston, TX
I got a second-hand yellow jacket manifold and I haven't experience leak yet. I rebuilt mind recently out of caution... cheap and easy to rebuild
smuro04
You most likely have the older set of HF gauges. The newer set in the ribbed case are a great deal, been using them for years now with no issues.
I say give the new ones a shot.
T
toyotadriver
I bought mine in 2010 but have only used them once before. They look brand new. The high side knob is plastic and broke when I tightened it. It's leaking somewhere on the manifold body.
Corndoggeh
Another vote for yellow jacket! It was a spare my father had that he gave me, never had a problem with it. I looked online out of curiosity and the prices are fair for a guage set, I've heard a lot of difficulties on the guages on the HF unit and I would not want to be second guessing the guages when I am diagnosing a problem.
