Moose97
I'm 48 years old and for the first time in my life I broke a tool using it the proper way. Split a socket right down the side. It was a Kobalt.
It happens sometimes. How much torque were you applying?
Might of been damaged before when being abused and this was the final straw, so to speak.
I just hear a lot about broken tools and this was my 1st experience.
I always wonder how people break their tools all the time. I use mine fairly regularly as well. I've since upgraded most of my tools, but I was using a lot of cheaper tools (COO China, HF tools, etc.) regularly and never had an issue.
OP, I think you may have just had a socket that had an underlying defect that was not apparent until you really had to give it some torque. Did it split right down the thinnest part of the broach?
I agree with the internal defect theory. A 1/2" 21mm socket should be pretty stout. ANSI standard for minimum torque rating of a 21mm 1/2"-drive socket is 424 ft lbs or 575 newton-meters. That's a 212lb man standing on the end of a 24-inch breaker bar.
Are we talking older Williams or Danaher USA Kobalt or newer Taiwan? Just wondering. Either way, it happens.
Every guy I've ever met named Moose was a big, tough S.O.B. Maybe you just don't know your own strength?
Sent from my XT1650 using Tapatalk
