corded die grinder
lightning02
what are some good corded die grinders to look into?
never owned one so i dont know which are good or bad. pros and cons.
Bobcat753
New Hampshire
I have a Makita paddle switch model and it has been really good. Only problem was I dropped it with a cut-off wheel in it and bent the inner shaft. $15 later it was back up and running smooth (Bought New Shaft). I love Makita for ease of getting parts and their tools always seem well made and overbuilt.
GaryM909
Calgary, Alberta, Canada
I have one of the Makita grinders with the aluminum body and toggle switch-works great. I had a Makita model with the plastic case and paddle switch - barely lasted a year, armature went. I also have a Dewalt with a paddle switch, It's been good so far. Some jobs I go on won't let me use a grinder with a locking switch so thats why I have to buy ones with a paddle switch that wont lock on.
bcradio
New Mexico
I have been happy with my deWalt paddle switch die grinder so far. I haven't used it a ton though.
L
lightning02
everyone that says dewalt or makita which ones do you guys own? they make all diff kinds with diff amperage.
rsanter
visalia ca
I have two of the dewalt 1/4in die grinders. I use the for porting and misc work. Have used the hell out of them for years
Bob
mechanical turk
Monterey Bay
I have a Metabo GEP 710. Variable speed with a paddle. I think it's a 6.4 amp, made in Germany. Can't complain so far but it's the only electric die grinder I have so I can't say if it's better or worse than the others. A little pricey, I got a good deal on mine but I think CPO has them for $250. I expect it to last forever but if something does **** out I would guess it will be the variable speed dial.
I kind of wish I had a toggle switch so it could be used in more positions and with a side handle, but it hasn't been an issue so far. One thing I like compared to some of the electric ones and all the air die grinders I've used is it has a lock button like an angle grinder, so I can change tools without needing two wrenches. I have mostly used carbide burrs, for which I just crank the speed pretty high, but it's nice to be able to turn it down for some brushing operations, and I have a cutoff wheel mandrel too. I think the book that came with it says what RPMs each number on the wheel is, but it's infinitely variable so I just try to get it close to the max for the tool.
I don't think I use any one tool enough to have a second grinder with that tool set up in it, but if I did I'd probably try to find a used on on craigslist or ebay. If you're just going to have one, the spindle lock button and the variable speed are nice features to have. I can't imagine trying to use a 3 inch cutoff wheel at 30,000 rpms and riding it into a low earth orbit.
tarbellb
Oregon
Definitely look into a variable speed, helps a ton with smaller applications and delicate stuff.
I have a Metabo I bought off Ebay for <$100, made in Germany, feels great. Makita was also on my short list.
GaryM909
I did have a Walter die grinder with the variable speed and locking shaft so you could change burrs or mandrels with one wrench. I really liked the grinder but it got stolen from the job site.
mbshop
visalia ca
Kind of hard not knowing what you plan on doing. I have used air for all of my career. I do use dremel for most stuff now. But as a tool dealer long ago I sold about 5 fordom setups to folks that did a lot of grinding including porting and such. So depending on what you plan on doing you may need more than one tool. I do fine with my air and dremel.
