Abrasive Chop Saw Blade - Brands
Jeeper
Round Rock, TX
Just picked up a Ridgid metal chop saw off craigslist. It needs a new blade. Any brands to stick with or stay away from?
Just a hobbiest, it won't get used much. Are diablo ones at HD good enough?
sberry
Brethren, Michigan
I use about any of them. On a small such as this user the thinner ones. The QC even from good mgfs is all over the place. Sposedly the thicker ones are 1/8 and 7/32. It doesn't seem to mean much as to how they list it, some say 7/32. Take a good look and compare, these machines are ok but dont have the real power to drive heavier blades as well.
I have several methods to cut, I like a chop for repair work. I almost never cut at angles with them, I am the designer and can straight cut most of the time or nip corners with a plasma. I like a saw with trigger lock, it can do a lot of things.
bobcatdan
Kaukauna,WI
Dewalt works just fine for me. It goes it streak of using my chop saw heavy for a day or two then it just sits maybe making a cut once a month. Blades last me years.
Cope
Houston, TX
I used Norton for years, and would still if anyone nearby carried them. I switched to DeWalt because they're available at Lowe's.
VocaTexas
I like the Pferd blades. They seem to cut a bit better and last longer than others I've tried.
Stevenn1
USA
All I know is the dewalt branded ones are about 40× better than harbor fright.
Somehow I ended up with HF (Chicago Electric?) saw and 14" discs. All stickers fell off. The discs break apart on heavy duty steel cutting. It bogs down easily. It vibrates bad too. It's OK for 1-2x year quick cuts i guess. But I would go Dewalt saw and discs next time.
crewchief888
NW indiana
i typically buy whatever is on the shelf at home depot, had good results with dewalt and avanti brands.
the HF blades ive had have been in the barely usable category.
YMMV
:beer:
MJD1
Norton, sait, flexovit or metabo. Buy blade at a welding store not a box store. There are many different grades, and a box store stocks them, based on price and profit margin, not performance.
