Know anything about this Airco Welder?
ejkuhl
Southern IL
My Grandpa gave me this welder the other day. It is an Airco MCM 180. Not sure when it was used last but it needs a new cord and plug that will fit my outlet. The leads are in good shape.
Does anyone know how old it is? Or where to find any other information about it? I can't seem to find any information or pictures anywhere on the net. I assume it will still work. It looks very simple. AC stick only?
American Locomotive
Rhode Island
It's an old AC stick welder. Pretty much indestructible.
Airco was eventually bought up by Miller, so they might be able to provide more information.
laser3kw
northen IL
Old iron and heavy copper windings - winner! Great for smooth arc stability, the arc seems to whisper.
bulldogr6
Good machine , can't beat free. Get yourself some e6011 & e6013 and enjoy.
Sent from my E6782 using Tapatalk
JimDon
Don't forget to get a fresh box of 7018AC for that welder. You'll ditch the 6011s and 6013s after that.
JimDon
E
ejkuhl
Southern IL
I have some 6011 on the way. This will be my first time stick welding. I have a 110v flux core that I use to put some light weight stuff together. Hopefully I can do a little heavier with this. I was also going to try some 7014 and maybe the 7018 if I get adventurous.
E
ejkuhl
Southern IL
I know the welder has plenty of fine adjustment, 75 full 10" diameter turns to go through the range. And smooth as butter the whole way.
sberry
Brethren, Michigan
There is the temptation to want to try every electrode ever invented, resist at this point. 1/8 6011, 10# of 3/32 7018AC and same in 1/8. They used other options back in the day because they had to, the advent of the 7018ac has made them less appealing.
A little out of practice but its a little loose on vertical compared to DC, you have to weave to make it hang in there.
bulldogr6
True about the 7018ac good call. 6013 is still good to dig through rusty stuff tho.
wagon
calif
Seconded on that being a Miller.
Not my pic - took it from google.
If you need new plugs/receptacles, Miller still has them available.
E
ejkuhl
Southern IL
wagon
calif
You're welcome! I remembered seeing that at Miller HQ in Appleton, and had to start on google to make sure I wasn't crazy!
Do start a thread, that'd be sweet.
Johnmcgowen
Oregon
I just got the same Welder! It was my father In-laws. It has been sitting for years, but adjustment handle turns smooth, all cords are shot. I am giing to give thus ol’ gal a try.
E
ejkuhl
Southern IL
Good luck. I have used mine a bunch since I first posted. Works great. As far as my poor skills are concerned.
