T-Handle that doubles as an extension
thertel
So an old timer I used to work for has these and I have no clue who makes them. I'd like to get a few for my portable tool box since they can take the place of a breaker bar, long drive extension, and the t-handle.
Any help would be appreciated.
bwringer
Indianapolis
Look on the wall at your nearest motorcycle emporium. Very commonly used when working on two-wheeled contraptions. Most moto-shoppes will have at least two or three styles.
Mr_B
Reading
You can just buy the drive section to slide on existing extensions, few makes do them and they versatile/affordable and some include step drive as well .
example >
gungatim
west mich
for that matter, just use a sliding t-bar on an extention...but I really like the craftsman one with the bit set. had it for a couple years now and use it all the time. haven't touched a speeder since...
T
thertel
Mr_B
Reading
Quite a few make these (good design has tension ball in bar hole)
Teng do them KS Tools do them Facom do them . cheaper makes do as well such as draper in UK/Europe .
Commonly found for 3/8 and 1/2 drive not seen a 1/4 but expect can get that as well
Teng P/N
1/2" male TENM380036 (image)
3/8 male TENM120036-C
1/4 male TENM380035
T45
There are 3 styles
1) T handle w/ removable crossbar (or use extension without crossbar). Still very popular, snap on, hazet, stahlwille and most german makes use these. Modern facom crossbars are not removable.
2) The Cman, Motion pro, and Sunex type spinner handles with square drive and sleeve. PB swiss and Facom make some alternate versions for hex and bit use.
3) T-handles with universal joint (square drive). The toptul is shown above, and Beta, Facom and USAG all do varations on this.
The benefit of each style is evident in different uses.
Applicatiosn like moto use the t-handle form factor alot because of the lack of spatial constraints and the multitude of small, low-torque fasterners which makes power tools verboten. The spinner and the universal style in one piece is nice because its stiffer, faster, and less likely to excess yaw angle or slop, and also applies torque better and less like a torque stick. The type that breaks down is usually found in generic/portable-type toolkits for occastional or mobile use where there is an advantage to that type.
Horses for courses, of course.
