Alexbn921
Wilton 300S vise restore
3 inch jaws and 26ish lb’s.
I picked this up on Craigslist for $110. It’s in pretty good shape to start and it is not missing any parts.
The action is a little sticky and it has been used outside for most of its life.
To start, I completely disassembled the vise.
Then I took a wire brush in a drill to most of the parts. The rust is not that bad and most of it came off with little effort.
I’m going to uses Permatex type anti-seize on all the threads. Super lube on the main slides and for a protector on the non-painted areas like the bottom clamp. Paint will be Rust-Oleum Hammered Metal Finish Spray, Verde Green.
I have some questions for the Wilton experts.
Is it worth doing a Molasses soak to get every last bit of rust or am I fighting a losing battle?
The center pin has markings on one side; do the markings go up or down?
Can you flip the jaws? Mine seen to be fitted/bent and only fit one way.
What’s the best way to clean off the rust on the horseshoe washer and handles?
