Tools from the old world
vintage nut
west coast of canada
Figured I'd share probably the best abrasive cutoff wheels I've came across. Dare I say better than any of the Walter products I've tried. I buy the 7" ones and use them on the black and decker until they are worn down to about 5". Then they get switched over to the makita.
These cut unbelievably fast, and last a surprisingly long time. I've even used them for cutting 1/2" plate when I didn't feel like using the torch for some reason.
Sent from my MotoG3 using Tapatalk
jask
Gods Country, B.C.
Lots of great posts! thanks everyone. That Makita 03 jigsaw is damn **** but at 400$ I am not going to be running out to buy one too soon..... added the image to my tool **** file though! ;)
losvre
UK
No coo but I am sure that 30 years ago it would have been made at the country originally developed and not outsourced.8796deb3e6103b22220a288574b6eccc.jpg
Sent from my SM-A510F using Tapatalk
losvre
UK
Just restored this knife by vinegar solution and virgin olive oil .
Sharp like razor and haven't touched it yet. Made in Sheffield, England.
Precivilization
Qatar
Unless you are talking about the kit where a charger and batteries are included, it maybe that much, but I only bought the bare tool (since I have the batteries and the charger) for US $219 of off ebay.com. It's made in the UK by the way if you are curious.
928'er
Wine Country, CA
It's a butter knife - missing it's silver plate.
I have two almost identical knives that I got in an odd-lot of kitchen stuff at an auction ~40 years ago.
I suppose you could put a razor edge on it - never occurred to me. It's a butter knife.... I use it to butter my toast.
neophyte
Pennsylvannia
If the blase in 10" give or take, it's probably a carving knife for meats like ham or roast beef. My parents had a set of Sabatier knives with a very similar looking knife.
vintage nut
Also a style of fillet knife that looks like that, called a butter knife for obvious reasons
That definitely isn't one of those mind you
Speaking of which I need to make a couple of those before salmon season starts in a couple weeks...
vintage nut
I've wanted to try a 6" grinder for a while... My collection has always jumped from the classic 5" makita right to the 7/9" black and deckers
My most used grinders are probably the 4.5" Bosch that home Depot often has on sale for 2 for $99
Never had a complaint about them.
Been wanting to try a Hilti, metabo, or fein though...
Bobcat753
New Hampshire
Vintage Nut- You can't go wrong with Metabo or Fein.
I would not buy a Hilti though. Talked to a Hilti rep about them and he said they don't last very long and to stay away from them, that should say a lot!
vintage nut
Good to know! My only Hilti experience was with their Rotary Hammers. Those have always seemed pretty unbeatable.
I'll keep an eye out for a good deal on a metabo
kris ltc
malaysia
My small army of electrician
kris ltc
malaysia
I wish I could get good tools as easily as you guys out there, is hard to come by in Malaysia thou.
losvre
UK
Nice collection.
May I ask if the foldable tape meter used somewhere specific? I am just wondering if a small measure tape would have been more convenient.
losvre
UK
Maybe you could try the Flex, also made in Germany and they are the ones firstly produced the angle grinder, I think.
I have a couple of grinders but I am looking to get a "better" one but cannot decide which one.
I don't really do much metal work though, just hobby and occasional maintenance.
lilredex
Toronto
A couple of recent acquisitions:
View media item 29649
View media item 29650
And restoration of the old Wolf bench grinder begins. I started with this:
View media item 28585
Not really in too bad a shape, but one of the bearings (both original) was bad. The zerk fittings both worked ok, but for some reason the grease wasn't getting through the wadding to the bearing so it had run dry for ages presumably. The other bearing was ok, but both are being replaced with new sealed bearings (I need to get those press fit onto the rotor hopefully tomorrow).
Anyhow it came apart, was dipped to remove the paint, and I finally got a bit of a break in the weather to spray some primer:
View media item 29645
View media item 29648
If the weather cooperates tomorrow I'll get some shiny red paint on it.
Here is another Wolf 6" grinder, that came from a friend around the corner.
There was enough of the label left to make out WOLF and a search lead me here.
The rests seem to be troublesome as these are not original either. Red appears to be the original colour. The small label on the base " Toronto 9 " and would put it about mid sixties.
I lifted the box hoping maybe, to see the original label (last picture), that I copied from another grinder online. but, it was not there.
It all runs very smoothly and can be used as is.
kris ltc
malaysia
Nice collection.
Yeah, is a old school measuring "device " that I'm still getting use to it. I using it for some tight spots with live electric circuit some time....
dutchgray
Dorset. England.
Those Wolf bench grinders are something we have quite a lot of in the UK, there was quite a lot of Wolf stuff sold here. Most of the ones I have seen with original tool rests, have very worn out tool rests, they seem to end up loose and left gently floating against the wheels, which wears them out faster than usual. These were a professional tool so got a lot of use. If I ever see a good one for sale im buying it.
vintage nut
My uncle has a wolf T handle drill, my grandfather bought it new in the 50s. It has oil holes for the bearings, not something you see every day
dutchgray
Dorset. England.
I Think Wolf was a German company, but am not entirely sure, I just know there is still quite a bit about.
I know the big heavy Makita 1100 planer is a copy of the old Wolf one, Dad had both over the years, I think quite a bit of their stuff lived on with other tool companies.
Monte
Germany
I have switched all my outdoor hoses from the metal quick release couplers to the plastic version!! I live in CA and the hard water caused havoc on the metal ones after 6 months. Tired of replacing them I finally broke down and tried the plastic, oh my SO much better. And lighter. That's the one time I wish I had simply gone cheap at the beginning.....
Don´t make me feel to regret my purchase :D
I hope we have softer water here :)
Yes after 13 years sad news that Edd China left the program (Wheeler Dealers). The rather stupid american producers Velocity, were intent on reducing the 'technical' content i.e. the workshop build processes ( which were the core of the show) 'too difficult' to make and too expensive - never mind that the obviously far more competent English production had managed all those years.
More product placement and advertising will be the result, and little doubt that it will become just another zero content/advertising full banal production like dream car garage.
There is a vid from Edd on utub: 'Edd China on leaving Wheeler Dealers'
The technical stuff was the interesting part....they rather should get rid of the other dude instead of Edd :) After a while it seems every TV show gets worse...same like orange county choppers....The fírst episodes were really good but later the show was more about son vs. father or father vs. son....:sad:
Excellent quality but a bit expensive.I have two quick couplings on air compressor.I also used it sometimes coupling from VOSS Fluid.Unfortunately I do not have pictures because I have them in Romania and i am at the moment in Italy
...yeah especially since they sold a similar set at Lidl for 5.99€ :) ...But i couldn´t resist the "Made in Germany" :D
A bit info about Wolf:
http://www.gracesguide.co.uk/Wolf_Electric_Tools
Nice tool wall :rocker:
1 kilo bondo from Feycolor for various projects :)
pozidriv
Belgium
That basin wrench is made by Alarm (part of the Stahlwille group).
The sockets are made by Stahlwille.
http://www.werkzeuggigant.com/item.p...831313&lang=en
@nowlan
I unfortunately have to disappoint you, but these sockets cannot be purchased individually, only in combination with a special basin wrench.
Hey Blöck, I've been looking at a basin wrench and stumbled across your post, that alarm 13 026 seems perfect, especially with the detachable claw.
However there's very little to find on the internet apart from just two websites.
Is it perhaps rebranded under other names or is it really a German only thing, only found in specialized plumbing shops?
Buying from werkzeuggigant would amount to almost €85..
Any good German secondhand websites?:beer:
losvre
UK
When your dad borrows some tools from your toolbag and use them for what they've not supposed to do... [emoji36] [emoji36] [emoji36] cdeac32594154cb49865ca9f88f99363.jpg
Haha, I think your dad would do well with mine. My dad does not borrow my tools he thinks he owns all of my tools!!!
At 84 yr old it is difficult to teach old dogs new tricks and so I just hide the best of my tools:lol:
Monte
Germany
I have one question -When is "enough" for tools? :dunno:
When you own all available tools from Hazet, Stahlwille, Gedore, Knipex, Toptul..... :D ;)
had to make a special tool:
cut off the box end:
after grinding:
welding:
finished:
...for installing anchors with the right torque:
(Don´t forget to calculate the right torque)
Snakevz
Varaždin, Croatia
Yeah, they would go together pretty well :D
Mine is 52, and I'm considering buying a few cantilever toolboxes and putting padlocks on them :D He's not that old, but his personality and behavior is story for itself :D When I told him that this is not 5€ tool, and how much it costs, he went voiceless :D Probably all tools he bought in his life are worth less that this pair of cutters, and they arent that expensive :D
To straighten out the mood, birthday present for my brother-in-law
Well, its not made in Europe, but still far better than China :D
gigamel
Nice torque adaptor - well made :thumbup:
If you turn it 90 degrees you don't have to change the torque setting. :)
losvre
UK
Do you mean to have the torque wrench vertical (90 degrees) to the adaptor before applying force?
How is that, and what if the adaptor varies in length?
Thanks
