bolt cutter, thread restorer help please
redsky49
near the coast in eastern North Carolina
I have a project where I need to trim the length of roughly 250 stainless steel machine screws, up to 1/4-20 in size. After shortening about a dozen of them I have managed to trash the jaws of my cheap bolt cutter, and cleaning up the threads of the cut end of the screw with a hand file takes forever.
Who makes a small affordable bolt cutter with jaws strong enough for stainless, and what is the best choice for a thread chaser?
Time for an "old world tool"?
Thanks.
A_Pmech
IL
I would build a little fixture to hold the bolt in an abrasive cutoff saw at the right length. Run a nut down the threads before cutting off. After the cut, run the nut off the threads to remove the burr.
Always works like a charm for me and it's very fast.
WVU Tuba Dale
Morgantown, WV
To cut the screws, I would use some sort of rotational cutoff tool and a vise. To get the threads back to where they roughly need to be, thread a nut down the screw past where youre cutting it, cut, then spin the nut off. If you want to get fancy, you can buy a thread restorer kit from sears (http://www.sears.com/shc/s/p_10153_... Tools&psid=SHOPPING01&sid=IDx20070921x00003d), and thread it down instead of a nut, then spin it off once you have cut off what you need.
EDIT: Or the device shown above, probably faster.
mrb
to answer the OP question about small bolt cutters, check out the Knipex ones. Best small bolt cutters i have ever handled. p/n 71 01 200
krehmkej
Oregon
I have cut lots of SS threaded fasteners over the years. Tried any number of bolt cutters and agree that the abrasive wheel is the best and quickest. After cutting, I then smooth up and bevel the cut end using a 1"x42" band sander.
hammlm
SE PA
Would this work I have used them with stainless and they worked great also as a thread chaser. Once you use it to cut them when you unscrew the bolt it acts like a thread chaser/restorer and works great one tool and pretty fast.
http://www.kleinconnection.com/weba...985_14921_true_1000_Multi-Purpose-6-in-1-Tool
+1 on smaller screws. Never seen one that would handle 1/4-20. Also hurts my hands just thinking about cutting several hundred 10-32's with one of those -- not to think about 1/4-20's.
70Chevy
The Motor City
Can't you just buy the correct length?
I know the local hardware store may not have it, but you might want to look on-line or a local industrial screw distributor.
R
redsky49
It just came to me in the shower (strange how that works isn't it?) P-Mech deserves credit here.
Mount a small vise on a plywood base.
Clamp the correct die (hexagonal type) into the vise.
Insert the machine screw all the way into the die.
Grind to length with my trusty Dremel tool (finally a reason for this thing).
Back screw out of die and the thread is restored. Hooray!
Thanks for the help :bowdown:
This application is to remount some ports on a boat. The existing screws are all cut to size and they vary from 1/16" variance on some ports, to about 3/16" differences on some of the larger ports. Very frustrating, but that's what boats are for.
Thanks again!
Mickey O
Chicago, IL
I agree with using a thin abrasive wheel to cut, to clean up the threads just put the smallest of tapers on the cut ends on a grinding wheel.
A_Pmech
IL
That will work.
Be sure to use the cutoff wheel in such a way that the torque reaction will tend to tighten the screw into the die rather than loosen it.
If you're unfamiliar with the Dremel, I suggest the fiberglass-reinforced cutoff wheels. They last much longer than the pressed garnet cutoff wheels.
Let us know how you make out with it.
mrb
What is with all these suggestions of using the correct part for the job?
Blasphemy I say!
