I have an old concrete slab in the backyard and I'm about to build a shed on it.
I want to keep my motorcycle in there and the usual yard tools.
Here in Vermont, we get a good amount of snow and rain and I'm thinking it will be best to raise the shed up off the slab.
I know it would be less expensive to just build walls, but I'm concerned about the wood rotting and the moisture from the concrete. So my plan is to build the floor on about 50 bricks to raise it up off the concrete and let the air flow beneath it.
I think 2 x 6's will be sufficient seeing that they will be supported every two feet and I'm using 3/4" plywood for the floor.
My intention is to brush all the wood down with wood sealer before I even start cutting, and to brush the ends after each cut. I did this on a shed I built on cinder blocks, in a shaded area, 25 years ago and the floor still totally solid to this day.
Do you guys think the height of a single brick, on a concrete slab will be enough air space under the shed so it will last a long time?
Construction starts Sunday.
