Destroyed a HF Breaker Bar
MrGiggles
Ruined this last night. No cheater bar, wasn't jumping up and down on it. I was tightening the lug nuts on a tractor with the bar at about 12:00 when it let loose.
I have to say, I'm a little underwhelmed after reading all the rave reviews about this thing.
bcradio
New Mexico
Never have seen any rave reviews about that one. Now the other ones yes I have seen many good reviews on.
vavet
Ashland, VA
Wow! Hope the failure didn't cause you to slip and hurt yourself.
I think we've all been in situations where we're not surprised if the tool fails, but if you're just using (not abusing), you might not be so prepared to brace yourself.
Does the particular unit have a lifetime warranty? If so, please post back your experience trying to use it.
rlitman
Long Island
Wow! Hope the failure didn't cause you to slip and hurt yourself...
Same sentiments here. I hate wearing gloves, but I keep forcing myself to wear them when wrenching. Too much knuckle blood gets spilled without them.
I may own that same breaker. It should be lifetime warranty at least.
davethorik
Norka, Ohio
There have been a lot of positive reviews of that bar on here. If I didn't get a steal on a Mac 24", I would consider it at that price point.
Looking at the pic, it appears the yoke cracked right where the radiused bottom meets the parallel inner side. It appears to not be fully radiused in the yoke opening.
bpjr
Florida east coast
Must be a defective one. I'm 200 lbs and jumped up and down on my 1/2" HF breaker bar to get a stuck axle nut off...no extension on the bar, just my weight. It broke the nut loose and didn't damage the bar in any way.
CNGsaves
KS and OK
Unusual failure . . . +1 for a dud. I'd guess that HF pin would fail first ??
Lucky that you weren't hurt when she broke. ;)
speed bump
Butte Montana
I think the breaker bar everyone raves about is the all metal one with a different head design. The style you broke is inherently weaker than the other style. I have broken an USA made Husky 18" bar with that style of head in the pin and my 24" Toptul bar is sketchy enough that I don't use it much anymore. The all steel HF bars have held up pretty well though.
bobcatdan
Kaukauna,WI
Dan
which one was cussed the most when it broke? :sad:
Was actually shocked I broke the breaker since this newer style has proven very tough to me. The ratchet was a bit of a curse as it was a long trek across the plant to get another ratchet.
jd_1138
NE Ohio
That's the "professional" one. The one that's half the price is good. I keep one in all 3 cars.
lightning02
im surprised the drive end didnt break first.
all my breaker bars have this same head design and never have i had one let lose on me. i have this bar as well and it never gave me a problem.
Corndoggeh
This is the one with the strong head.
That thing never broke on me, had to change a CV axle and the nut on it had rusty crud in the threads (and before I discovered 50/50 atf:acetone mix) and put almost my entire weight on the end, it flexed somewhat and broke the nut loose.
The one OP got is a weaker design, essentially you put the entire load on those two prongs versus the all metal one distributes the load more through the big fat head.
Mr_B
Reading
the OP one is better design, poor metal stock probably the cause, that yoke design goes back decades and is more expensive manufacture over the slotted head type use on budget bars, I got breaker bars 60 years old that take a 4ft pipe no bother.
1982fxr
Phoenix
....that you know of. Yet.
Wakefield
Arlington VA (but would like to get out to country
Old S*K that has a longer thick section at the neck before it tapers down to the handle diameter? (Has fork on the handle,not the head.) But stays thick for about an inch below the fork before tapering down.
ChevyEFI
Phoenix, AZ
That's a whole thread in itself!
How old are talking? Don't think my 16" 1/2" breaker has that and it is pushing 20years.
dnschmidt
Phoenix, AZ
I like the new professional design from HF more but the older design is inherently stronger. TOPTUL makes both types and recommends the bulkier (first HF design) for the higher torque applications. The reason I like the second design is I can use my Eclatorq digital angle gauge on the head of it when tightening down Subaru head bolts whereas I can't with the bulky design.
I seldom if ever use a breaker bar as I've got super powerful Aircat and Milwaukee impacts. The only time I use them is to remove head bolts on Subaru's since their foot long head bolts act like torque sticks making an impact ineffective.
Loscaldazar
Is that a 1/2 drive or 3/8 drive one?
The 3/8 drive one is known to be weak. The 1/2 drive one that people rave about has a different head design (the bar portion is a straight piece with the swivel head with the drive tang being U shaped and bolting over the straight shaft of the handle).
MrGiggles
1/2"
The only thing that I think could he a factor in the failure was that the bar wasn't 90* with the fastener. I was only using a deep socket and no extension, it was angled out a little because of the wheel.
Wakefield
The ones I am thinking of had a pin,not a bolt through the fork and pivot. I have a little shorty version like that,I think only 9" or 10" long. When they went to the bolt seems to have been when the thick section below the fork got shortened. I remember Mr. Holeshot who used to post here described his 18" long (?) one that he bragged on the strength having the pin.
(The pin on those S*K are larger diameter than used on some other brands (like Craftsman which I think used to same pin as Armstrong (at least my Craftsman)
damn time flies,my new Craftsman might be 20 years old! It hasn't broke but with what I hear about Craftsman it only gets trusted for routine things like lug nuts. (these being 1/2" drive)
dogdog
.......tractor lug nuts... shouldn't you be using the 3/4 breaker bars instead ?
kctyphoon
Jersey/Staten Island
I was just using the 1/2" extending ratchet to press out leaf spring bushings. I literally had it to the point I could barely more it anymore, and it was fine.. the HF breaker bar has served me pretty well too, so maybe yours had a casting issue? Luckily you can just walk in and get a replacement. If you have some crazy sized lugs, maybe the 3/4" is an option for you..
CNGsaves
KS and OK
^ ^ Where is that picture of GJer with 48" or longer 3/4 or 1" drive breaker bar ??
Imagine that would be an "easy" pull even on tractor lug nuts !! ;)
Farmall 1066
Suburban Rockford, NE
When OP says "tractor lug nuts" I'm envisioning Kubota or some compact tractor, where 1/2" is acceptable. Don't think it's a Steiger Tiger. Lol!
I've broken my Snap On one idk how many times, in same manner as the OP. Bought the SK 30" a few years back and can't believe the abuse it's taken.
Eric29
Western NY
This is why I don't use HF tools. It just takes one thing like this to seriously injure yourself.
Infinia
SoCal
yup +1
the customer is part of HF QC process
HanShotFirst
NW Nevada
You know, I RARELY lose tools, I'm pretty **** about putting everything back. But somehow I managed to lose one of those breaker bars.
In the mean time I picked up one of the Pittsburgh Pro ones and it has served me quite well.
Just an observation I find a bit funny. When a Harbor Freight tool breaks, It's because it was a cheap POS. When any other tool breaks, its some sort of deep mystery.
