2017 Lowe's deals/sales/clearance thread
pdxman1
Try these
470001118671194
470003340571198
470002371371197
470000617171198
470003355671197
470004861271192
470000827971199
470004745671193
470002901771190
470000737471192
470002989971192
470000542971191
470001934571197
470002440971198
470004350071197
470001494471197
470000486071193
470000925371198
470003356471192
470001072771190
470003614171192
470002941371190
470001125971195
470000812171191
470002154571196
470001320471193
470000755571195
Thanks. Used the ones in red. They are $15 off $50, by the way.
hootyburra
Lowes in Bloomsburg PA had 50 lb boxes of 11 gauge 1-1/4" roofing nails on clearance for $5. Item 108024.
6 left this afternoon.
Also had multiple gcfi breakers, mower blades, misc at steep discounts.
homeschool
Sent from my XT1254 using Tapatalk
EOC_Jason
Bentonville, AR
It really only requires basic excel knowledge... There's other SD threads explaining the following formulas.
Pretend this is cell A1. Basically here is an example of the first 14 digits of the $15 off $50:
Code:
=47000&TEXT(RANDBETWEEN(0,55000),"00000")&7119
Replace the last 4 digits as necessary with new expiration codes (from link you posted). Also 10% off codes can use 99999 instead of 55000.
Pretend this is cell A2. This code generates the 3x weighted average check bit (last digit), same principle as UPC, ISBN, and other barcodes...
Code:
=A1&RIGHT(10-MOD(SUMPRODUCT(MID(A1,{1,2,3,4,5,6,7,8,9,10,11,12,13,14},1)*{1,3,1,3,1,3,1,3,1,3,1,3,1,3}),10))
There's no black magic involved... Press F9 in excel to refresh cells and generate new codes.
kneeman
Code:
Code:
Posting ways to make false lowes codes that work can't be good. You're taking a code that a targeted lowes customer was mailed to use.
Lowe's is aggressively going after sites that pop up offering code programs. They shut down several over the past few months. Not sure why you'd want to post this here.
Sent from my SAMSUNG-SM-G935A using Tapatalk
EOC_Jason
Bentonville, AR
If they haven't forced SD to take down information that has been available for a couple years now they can't be working that hard.
Sh40674
Iowa
no but all good things come to an end. would be much easier to keep in through a P.M. instead of in public view. the more public view, the faster it will end.
homeschool
Alchymist
Central PA
Just a heads up for veterans using the 10% discount - Lowes is doing away with the cashier ringing up the discount. Only way now is to have a MyLowes card and have the discount (eligibility) linked to the card. Then when the MyLowes card is scanned the discount is automatically applied.
The Lowes website is kinda screwed up it seems, and I was unable to use the verify service page. Not only that, the Lowes website said I didn't have a MyLowes card, which I do. :dunno: However, the site did say it could be done at the service counter in the store. Will try next time I'm in.
ishiboo
Oshkosh, WI
Seems kinda odd. Much easier to use someones MyLowes card than to have their military ID.
2manytools
Mt Pleasant, MI
that's my first thought. Now I just take my Dad along on big purchases as they are quite the sticklers, even when they remember you from the last time. Well hopefully it doesn't get abused like their coupons, and stays around
Alchymist
Central PA
They didn't say if you still had to present military ID - just that the cashier could not enter it, it had to come from the MyLowes card. Perhaps they will still ask for ID? :dunno:
EOC_Jason
Bentonville, AR
J/K, I rarely shop lowes as I find their prices to be higher than HD
I'm really getting peeved at Lowes on them cheaping out... Like yesterday I wanted a coupler for my pressure washer to connect two hoses together...
Lowes was anodized aluminum (colored to look like brass but the weight was a dead giveaway)... $4.98
HD was brass... $4.72
:willy_nil
dh1
I ended up having to disable all adblocking items to get their page to work.
Reit38
Iowa
Was there a rebate goin on 4/27 ?
Sent from my SM-G930R4 using Tapatalk
anuccite
Richlands, NC
For the Coupon Codes...... Can I create multiple "pick up in store" orders for the same day using multiple coupons?
I'm building a room in my garage, and have over $750 in materials in my cart.... I want to split them up, and use multiple $50 off of $250.....
Anyone ever do this, and pick it up all in the same day?
OxJaw
Medina, Ohio
I've done it with smaller orders. I don't see why you can't. The worst they're going to do is cancel the orders.
onuxis
Something is messed up with it. I couldn't register with the active or reserve verification, but I picked "veteran" with my last DOS/ETS and it was accepted. And yes, I'm still in the military :)
chrisexv6
CT
Ive done it. And each order was exactly the same, so I called them and told them its not a mistake....please fill all 6 orders.
They managed not to eff it up, either.
rahrah12
Pacific NorthWest
I've done it before. Doing it today actually. two identical items I want to use $15 off for.
Both are ready to be picked up.
kevc
Torin magnetic bit holders down to $7.**. Managed to get the display model for $5
ItsFriday
A few days ago Lowe's started discounting the 50-ft fish tape, as low as $2. I got 5 for $4 each - normally $60. The 100-ft is also on clearance.
Southwire 50-ft Fiberglass Fish Tape
Item # 471914 Model # FTFG3-16-50
The reason lowes is discontinuing these 2 fish tapes is because there is a new model that has bright green on the end. It looks the same quality, but the new ones are $70 for 50-foot and $90 for the 100-ft version. So buy now or you'll have to pay a lot later.
64merc
Texas
Thanks! Got a 50ft for around $14. I don't use them often, but I've been keeping an eye out for a new one.
rbt7
2- Havahart traps at Lowes. They have two traps one inside the other for $28.50. one is large and the other is medium size. It was not advertised on the website but was in the store in Riverdale NJ. They had a whole pallet in the garden center.
Sh40674
Iowa
saw on the website they have up to 30 percent off hitachi stuff... pretty good deals on there especially when combined with a coupon
Thirdyfivepickup
Portage, Indiana
:willy_nil
I went to Lowes a few months back for pellets for my wood burner. I just bought a house so I'm unfamiliar with pellets. Lowes had me waiting around 20 minutes for an associate to help me... two pages and no one showed up.
I went across the street to Menards. The lady in lighting greeted me and took me right over to the pellets and I was out the door in 5 minutes.
Service alone I'm a Menards guy.
gamp945
Thanks for posting this. I found one for about $12. This will really come in handy this summer as I'm going to be doing quite a bit of wiring. Thanks!!!
Sh40674
Iowa
Ditto. I live at Menards, but Lowe's knows how to do deals. And I buy my appliances there for the return policy and extended warranties
bubinga
Its hard for me to get any body to help me at my lowes.
I had to get a guy from a different department to help me.
Then the girl from that department kept running away.
Then I asked another guy, where is everybody at, are they short on help,
he said" we're closing"
I said, don't give me that "You're closing ****, I have been here 2 hours trying to get help"
Yeah, My Lowes *****,
Then They very very seldom have anything on sale posted here.
Super Sport
West Michigan
Thanks, ordered one for $8.71 at my local store. :beer:
