I need to get a A/C disconnect connected next to my mini-split for my finished garage. I have a sub panel inside the garage and need to pull a wire to the a/c disconnect which will need to go through appx 3' inside a 2x6 insulated wall, come out through the exterior sheathing and siding and drop down another 6' (inside a PVC conduit) on the outside of the a poured concrete wall.
What type of wiring should I use?
What kind of box or transition would be the best to come out of siding? Do I use a siding block?
I do not want to run the conduit inside the walls since its already drywalled and I did not want to cut it all out.
