I found out about a mini split tech session that was occurring the other day .. and was able to sneak a spot with one of the guys I know. It was held at one of the larger distributer offices.
It was an interesting few hours -- and an eyeopener as to the problems the HVAC industry has. Not being part of the industry I was reluctant to get in too deep .. but, I finally had to ask a couple simple questions.
I wanted to know ...... what's the biggest reason for failure?
Not surprising .. it's installation. And a huge problem is installers using pre-made line sets. You have to use the manufacturer's fitting -- and re-make the flare joint correctly .. evidently, making them corrrectly is a bit of a mystery. Both of these points were not a surprise, as I had read about them previously. Most leaks occur at the joints -- the unit become undercharged .. and the problems start. Often, the leak is not located and the tech overcharges the unit later when servicing.
Another item that was pointed out by one of the guys in the session -- and said as sort of as a joke. He said .. "guys ... please use a level and don't try and eye the unit"
Unfortunately, 1/2 of the session was really a sales pitch for equipment .. but some interesting items did come up.
I used a mini for the first time about 15 years ago. The guy who did it was a real pro -- it was early in the game ... so, he was learning and took his time.
IMO the industry has work towards better installation. Simple things like better instructions .. items to make the installations neater and more palatable for US consumers is needed. Most of the installs I see are horrible -- the big manufacturers should spend some money on batter equipment mounts, lineset covers ... even something as simple as a better way for all the stuff to go through a wall.
I see lots of installs that look as if the installer gave little thought as to how the whole job was going to come together.
That's overkill for most people...
