Hi,
If you want to use a clear on the floor you must use a special UV inhibited non yellowing epoxy and then clear topcoat (All true epoxies can yellow from UV if not protected). Clear primer is strongly recommended so this system could end up costing in the $1.25/sq ft range.
A less expensive option would be to use our clear SPGX, fleck into it, and then a second coat to topcoat it. About $1.00/ft and only two applications instead of three.
