cdaiscool
Hello there! I am about to start working the ground to put a 12x12 concrete pad down for a shed, and I've got a couple questions. Tried to research, but either my Google-Fu isn't working or I can't find something that really looks like what I need.
Most of the ground is flat, but it is on top of a small hill. One corner is 10" lower than the other corners, starting from about the center. Even if I do a 1" drop every 4 feet for drainage, that's 7" too low. With that said, how do I rectify this? It's more or less gotta be here, much closer and the township says no permit, much further away and the HOA says no shed.
Should I just pour enough concrete to make it flat? That could be a 7" thick pad, 12x12. I'm just putting motorcycles on this, not a school bus.
Do I put gravel under it, and do it so the slab is 4" thick on the high side, ~7" thick on the low side, basically following the grade? That would mean the bottom isn't flat, can't it over time move?
Do I put in a retaining wall, and the wall of the shed lower than ground level? Or build up the low side, knowing I'm no longer on undisturbed clay?
One article I read basically suggested to make a hump in the middle, so the edges are closer to 7" but the middle is closer to 4" thick to save on yardage for the pour. Another good idea? Bad idea?
Until I found the low spot, my initial plan was 2x6s for the form, and gravel 1.5" followed by a 4" slab. I live in Michigan, the back yard is clay, and I'd like to do this right.
Thanks for the advice/help/responses!
