rope for moving heavy things
Roberts210
Missouri
It was a sad day when hemp ropes were taken off the market. They were and still are hands-down the best type of rope.
zak77
Monson, MA
i slide a 800lb woodstove down a bulkhead with crappy ratchet straps using my truck to slowly slide it down on some 2x6's. Even clothes line rope would be strong enough for the OP's purpose.
PugetDude
Superstition Mountains, AZ
Just about any 1/4"- 3/8" rope would be enough to lower a 200# filing cabinet down a flight of stairs. With a 37-40 degree stair angle and frictional resistance, there will be very little actual weight on the rope, probably under a hundred pounds. (unless you let it go and it builds up a head of steam before it takes up the slack...) It's just not that much of a load.
In fact, you could probably braid something suitable out of pocket lint and the hair from your shower drain....
Put it on a stair dolly and forget about the rope; it's just going to be in the way of the dolly anyway.
