will this be enough light
oldno3fan
12 of these 6 on each side http://www.beeslighting.com/product-p/dv-ls4-40l-50k-d10.htm
shop is 17x25
profile.php
matt_i
SE Michigan
If you're wiring an open ceiling, its a very minimal extra to prep for a 3rd row in the center. If you don't need it great, a few extra feet of romex is there, imo less than the cost of 1 fixture. But if you do need it, its just plug and play or complete the hardwiring below the ceiling.
I put 10 of the costco 42W twin tube LED fixtures in my shop and its quite bright already. Wiring is in place for 10 more as the budget allows.
Angelfire
New Mexico and Ireland
Agree completely. Wire up for extra (it's cheap insurance) and wire it such that you can switch on what you need when you need it.
cybrdyke
USA
Oldno3fan,
That's way overkill for that space, but if I recall, you have a vision issue, correct? If so, and if you are going to spend tons of time in the space, I'd ask your doctor about the effects of heavy blue wavelength light over extended periods of time. :thumbup:
A different solution would be T8 or T5HO fluorescent. Not nearly as efficient as the LED, but not so heavy in blue wavelength. And you can still get the 5000k color you want.
Another solution would be to back off the overkill on the general illumination and to focus on maximizing your light in the work areas with task lighting.
ABout 120 lumens per sq ft....
No. It doesn't work that way. Lumens per square foot means nothing.
Good luck
CD
ALinCarolina
NC Piedmont
CD, can you elaborate or post some links so I can read about the long term blue wavelength issue? For instance wouldn't using a lot of natural sunlight through skylights and big windows mean using high Kelvin light?
Reason I ask is I will soon be choosing fixtures for my shop. Currently have three test fixtures up, one each using 4100, 5000, and 6500 K and I seem to like the 5000 best. But I don't want to make a mistake since I will be using the shop a good bit as I will be retiring.
O
oldno3fan
anyone is there a way to calculate this correctly before i order with the light be even thanks
Angelfire
You haven't defined your requirements so it's hard for anyone to say "it'll be enough". Do you want 50 FC or 100FC or what? How are your eyes? How old are you and are you planning to be in this space for long? What are you doing in this space?
Personally I overbuilt as my eyes aren't as young as they used to be. I built to 100FC but have it arranged so I can turn off lights if what I'm doing doesn't need that much.
Here's a tool I used, and while there are experts on this forum that can do the calculations themselves (and possibly more accurate), I found the tool to be helpful:
http://www.visual-3d.com/tools/interior/
As well, this article helped to put it all in perspective (ie. FC, Lumens, coverage, Lux, etc...):
http://www.sawmillcreek.org/content.php?146-Lighting-the-Small-Workshop-by-Jack-Lindsey
I'm not saying these are the definitive tools/information to use as I'm sure there are others that know better, but they worked well for me.
Cheers.
b-dog
Lakewood, CO
Cheers.
Good links with great info!! The calcs on the second link suggest that I need 35 fixtures for my 650 sqft garage at 100fc and a loss of 50% with the costco 3700 luman fixtures. Seems a bit excessive. I was thinking 12-16 would be pretty bright. Do my calculations make sense? I'm thinking maybe the 3700 figure could mean PER row which would actually be 7400 lumans per fixture. If that's true then my wild guess of 12-16 would jive with actual math!
On the first link, which is also pretty neat, any suggestions on a particular lamp that would represent the costco fixtures without having to go through each one, comparing specs?
For reference: Costco Fixtures
Cheers!
Angelfire
Sorry B-dog, I'm going to have to defer on the tech questions! When I did my calculations, I found a standard T8 fixture in the library and just used that. I may have even asked the board for a recommendation (did it a long time ago if I did). As for losses, that will of course vary by fixture/lamp/etc...so figuring 50% loss may be a bit much (I don't recall using that much and with LED, I think the loss factor is less although one of the experts here will need to confirm/refute that).
Cheers.
b-dog
Lakewood, CO
