SK Wayne 3/8 ratchet 45170 bends, is it normal?
dogfight
Dear all,
I buy a second hand SK Wayne 3/8 ratchet (45170). I receive it and figure out that the neck bends a little bit (attached images, first image shows it bends)
My question is: did SK make it bend, or it was bent by accident? Please help me.
tym
By "bends" do you mean it flexes when you use it? Or do you mean that you used it and it bent permanently?
If it is flexing/bending, how much torque are you applying to it? Mine is quite solid in use--in fact, I used it two weeks ago to break loose suspension bolts on my car without any flexing or bending.
D
dogfight
Hi tym,
My question is: Or do you mean that you used it and it bent permanently
it is a used one, I buy it in internet. I just received it yesterday. It seems that working well, but I am still worry about the bend.
tym
So it was already bent when you got it?
That probably means somebody abused it. If it concerns you, you can always buy another one on eBay--they are on offer frequently and not terribly expensive.
D
dogfight
Yes, I just received it.
I am not sure how they can bend it like this, because the neck is very sturdy compared to the head complex. I still think that when applying force, the head should be broken first.
firworks
IL
View media item 70437View media item 70436
Yours looks OK to me. This is a vintage SK-Wayne 45170 along with a more modern SK 45170. I think they have a slight bend backwards like that. If you think about it, how would you even abuse a ratchet to bend the handle backwards like that? If it were bent in the direction you apply force to tighten or loosen a fastener sure maybe it was abused but... Unless they were using it and a socket to take off bottle caps I don't know how you'd ever bend one like this.
D
dogfight
Yours look a little bit bend but I see that mine's bending angle is much higher :(.
txlch
Can you take a picture like Firworks ratchets are? It does look to me yours is bent more but a picture from a similar position to compare would help
D
dogfight
Hi,
In my previous post I post a similar picture. Pls take a look.
Ole Slewfoot
Freedom, CA
Probably got ran over. You can put it in a press and bend it back if it bothers you, or return to sender if they were shady about it.
B.S.A. (ret.)
Central Connecticut
It looks unused in your photo, but if it is marked "S-K Wayne", it is approximately 50 years old. If you remove the ratcheting mechanism and then place the body on a level surface you may be better able to tell if the handle is bent or if it is only an illusion. Either way, it is completely serviceable as far as a tool.
thehorse13
Jefferson County, WV
I've never come across an SK Wayne ratchet with a 15 degree bend in the handle. It could be a factory defect or as someone else suggested, it may have ended up under a truck tire.
All of that said, it's not a rare, expensive or collectible ratchet. It can be used without issue as is. If it bothers you this much, sell it and grab another one at the local flea market.
finn
The UP, God's country
Most likely was bent during the manufacturing process in 1966.
It made it 50 or so years and will probably go another 50 without affecting performance, but if it bothers you, a few minutes in a shop press should straighten it out.
That's the process they would have used in the factory to straighten it in 1966.
crazymonkey2465
San Antonio, Texas
I would leave it how it is. I'm not very familiar with SK tools, but I know Hazet sells a ratchet with a bend in it like that. I assume it is for knuckle or finger clearance, pretty smart in my opinion.
bubinga
Hey, Never know, Might save your **** some day?...........lol
I agree, I wouldn't worry about it, or, as stated, straighten in a press.
Place across some metal support, protect with rags or leather, 0r use wood supports.
Wood "may" give too much not sure.
Really though, as said, I wouldn't sweat it.
Just do like the rest of us, and get about 14 more.
Keep a kit in your car. Make that the car rat. if you're not crazy about it.
Richard Cranium
central Washington
I would leave it alone, Don't really matter one way or the other. If it really bothers you box it up and send it to me. I will keep it safe for you. I have a place in my tool box awaiting it's arrival. Rich
D
dogfight
Thanks.
Pls show your irregular items in your toolbox to make sure that my ratchet will not be alone. :beer:
davethorik
Norka, Ohio
I have an SK Dresser era 45170 and the handle is slightly bent opposite of yours dogfight, it puts your hand closer to what you're working on. It was bent when i acquired it nos.
SuperCat
Sacramento, CA
I have "more than" several used SK 45170 3/8 drive ratchets that I have acquired over the past few years. They are from different years and eras, and none of them have a bend in the handle like yours. However, I see that as an advantage for knuckle clearance. I would use it, as is, and report back to us on whether you like the bend or not. I suspect there are some people here who would bend their handle, now that you have shown yours. If there is no obvious damage to ratchet from an accident (like being run over by a truck) or signs of abuse, it may have come from the factory that way. Let us know what you decide, I've never seen anything like that before. :thumbup:
twertsy
Reedville, VA
Notice also how, between the 2 examples shown up front, the heads merge into the shaft differently. If I remember I'll take a look but I personally think it's an illusion. Other than intentionally, like in a press, a truck would be just about the only option to bend it that way........and I bet that wouldn't work.
Technics
The bend makes it even more functional :) I certainly would keep it, and if it bothered me enough I'd just get another one to go with me!
