I've been using a string trimmer I purchased recently and I find when I try to edge with it it dies a few seconds after I rotate the shaft 90 degrees. I played around with the trimmer and it appears as though the fuel line doesn't always flop down into the gas when rotated. For some reason the fuel tank isn't exactly cylindrical. The tanks has nooks where the fuel filter (on the end of the fuel line) is getting caught. My question is, short of replacing the tank, what can I do to ensure the fuel line actually falls where it needs to? I don't want to shorten the fuel line either as it's the perfect length to get most of the fuel out of the tank.
I thought about adding a lead fishing weight to the middle of the fuel line. That way if the filter gets caught in a nook, the weight should be able to pull it free. Does anyone have experience doing this? What could I use to possibly secure the weight to the fuel line?
For reference, the trimmer is a Maruyama B23L. The parts list can be found here if you'd like to visualize the fuel tank.
