Who makes super thin combo wrenches?
visionguru
Chicago
When I was replacing the transmission filter on a 2007 Honda Accord, a 10mm bolt took me 20 minutes. The problem was: it's in a very tight place. My Gearwrench racheting wrench couldn't fit in there, too thick. I had to use the open end, 1/6 turn at a time. The bolt was rounded a bit.
Anyone knows who makes super thin combo wrenches?
mlum6969
i have a set of super cheap wrenches to modify.. just take it the the grinder to make it fit.
T45
Which part of the wrench was too thick? Please be specific.
Agree...Lots of crappy combos have clearance problems; even more so with gearwrench style tools. Regular combos are usually taller in the ring end than the open end. Since the GW combo worked, I don't think OP needs a true thin wrench. More like a box end with better clearances....that maybe best done with a grinder. Switching to a non-ratcheting will help with ring width, as will using a higher end brand with thinner rings, and lastly an aerospace type design. If you need to shorter ring height, not width...then its pretty much a grinder on a cheap non-ratcheting combo.
pstemari
Seattle
I've never seen combination tappet wrenches, just DOE. If you really need super-thin ones V-8 tools makes a stamped set. I had a jam nut on an Atlas lathe where a Proto tappet wrench was too thick. Snap On might have worked, but the one wrench would have cost more than the entire set of V-8 tools and wasn't worth it for a one-off job.
Sent from my Pixel XL using Tapatalk
Tuc04
Facom makes DOE in metric that are thin. FM-31.JE6T
According to Zoro they are made in Italy if that matters to you one way or the other.
4 FN 27
Minnesnowta
We make them for a well know American Tool supplier once and a while. Just ran these a week or so ago.
tvtaurus
Indiana
I picked up a set of craftsman tappet wrenches recently. That fits your bill.
Sent from my SAMSUNG-SM-G900A using Tapatalk
Skin
Boston
Considering the OP was complaining about using an open end I don't think tappet wrenches will interest him. Sounds like he wants a low profile box wrench.
My suggestion is bench grinder.
mowkep
Stow, Ohio
I have a 9pc Craftsman Max Axess low profile combo wrenches new in the package I have been trying to sell.
Stevenn1
USA
The Craftsman 'tappet wrenches' only comes in SAE & open end, sounds like op wants Metric. BTW, I got the newer 5pc set, they don't say coo but seem to be OK for low torque applications.
ryan20021982
Northern IL
I buy bluepoint tappet wrenches at estate/garage sales.
The OP said combo wrench not tappet wrench, if you read the post he used the open end to get the bolt out.
V
visionguru
Chicago
Guys, thanks for the tips. I learned something new by googling the different wrenches you guys mentioned.
The first picture shows the 3 10mm wrenches I have: Mountain Spline Drive, Great Neck, Gearwrench reversible. I want to be able use the racheting end, but both the Mountain and Gearwrench was too thick at the racheting end. The box end of the Great Neck was ok, but has a big offset, which makes it unusable once the bolt come out a little bit.
The 2nd picture is "Midget Combo Wrench Set" sold at Menards. From the looks, they might work better in tight places. While I prefer racheting wrenches, having a set of these might make life easier next time. Unfortunately, the metric set was sold out.
Two observations of the tool selection at Menards.
They have a lot of "Made in USA" stuff.
The "Made in China" wrenches from Crescent are as good as GearWrench, but 50% cheaper.
nbpt100
Massachusetts
I was thinking the typical 15 degree offset on the box end may be working against you.
There are box wrenches with no off set. Bicycle wrenches come very thin but they are low torque.
T45
A short (160mm), minimal offset (0*) is available, eg in aerospace series
XDHSFM810
Dimension A, Head Dia., mm 12.1–14.9
Dimension C, Head Depth, mm 6.2–7.6
Dimension E, Length, mm 162.9
Finish Chrome
Size, mm 8–10
Style 12-point
Country Of Origin USA
Brand Snap-on
A specialty wrench you'd have special order, it may be of interest for ideas tho. (pic is a stock photo of anothe size).
metaldad
nw indiana
go to all the menards in the area to find those wrenches.
they were made by apex, which has ended all USA production last month (armstrong, allen, kd. those wrenches were rebranded allen).
menards is restocking with gearwrench.
Wamsutta
Amarillo, Texas
It appears that we'll never know the real reason why the original wrench in the first post was too thick. There's all kinds of dimensional thicknesses on a wrench.
