Just whipped this together today.
I was skeptical but definitely there is enough flow to wash your hands.
My question now is do you think it can "power" a faucet? my plan is to get a little laundry sink, next time when the water heater needs to be replaced. I would have the plumber tee off the plumbing which is probably the easiest way to get water supply in the garage. But if it works well and this 7 gallon bucket should last me reasonable amount of use. I may just use it this way.
I think the drain can tie into the gutter. It's not different than me washing my hands with the garden hose outside. But if the gutter/French drain is clogged does that mean the water will come through the drain ?
