Cool! Any grease will do?With a standard grease gun and fitting.
Yes!Umi?
Yes!
My current ones' bushings life has expired and I decided on getting tubulars to reduce wheel hop, negligible weight and poly bushings.Standard grease gun fitting.
When you install them the grease fitting needs to be pointing down.
Not knocking you, but if you're asking how to grease them I'm wondering if you should really be installing them? They are fairly important.
I don't know what grease fittings are because I have never worked with grease fittings. I do, however, know the ins and outs of my car. I've replaced trans mount, sway bar end links, sway bar bushings, upper and lower control arm bushings (friend had a press at his shop), strut mounts, coil springs (front and back), struts, shocks. So yeah I've done a fair amount of work on my car.
I was simply asking how to grease the arms.
Understood. All ploy bushings should be pregreased. Remove the sleeve and use a lube designed for poly. I am to assume with a fitting this is a two piece split bushing. Issue with those off-road is they collect water and rust. Packing the grease in forces out the water. However unless the bushing has grease grooves. It does little to nothing for lubrication on new bushings. I take it this is a street car by the photo.
Pull the sleeve, pack lube in and then lube the sleeve before pressing back in. Poly lube is sticky, grease is not. It has to adhere to the bushing to not make noise.
