Ok pic as mentioned.... it's working now, just waiting for a TPDT switch so I can finish it up.... no sure why I needed a reversible drill press... but heck it's been fun learning experience....
It's easier than you think....
Use common sense lots of it...
following the diagram from the link on previous post... I needed to identify the start winding and thx to the hints from "lilredex" found one end of the start winding the other end was buried in these heat insulators. pic IMG1..
Checked every heat insulators all have 1 magnetic wire except the yellow confirmed with a continuity tester...... cut wire separate into two, identify which wire go which with the ohm meter. ... mark and add an extra wire.... for the separated start and primary winding.. use mechanical crimp then solder over it... slip back the fiberglass heat insulator. (this would be one end of the start coil) Re-tie everything. nicely back. IMG2 IMG3 IMG4
cut and break the original blue wire that goes to the end of the centrifugal switch. Added a new wire out... this would be the other end of the start coil with the centrifugal switch capacitor.... IMG5
Tuck everything nicely and close cover... IMG6
Verify the coil resistances should have 3 coils.... W1 W2 are the primary running coils.... W3 the start coil...
Test on the test bench.... in my case a fused switch ..
As the plate indicated.... for 110V...
Original configuration...
Connect black Red and new Black wire for Hot , Connect Yellow Grey and new white wire.... for neutral it rotates ..
Connect black red and new white wire for hot, connect yellow grey and new black wire for neutral, now it spins the other way....
Now just waiting for the TPDT center off switch to complete the switched reverse installation. TPDT instead of a DPDT.... is because I wanted to break the Hot wire while it's on Center Off, not to accidentally switch to reverse or start the motor while the start coil is not connected... Any comment on this part is appreciated. More of a safety thing...
