why tapered drill bits?
vavet
Ashland, VA
I bought a set of drill-countersinks a few days ago at HD. I really started looking at them this morning an realized the included drill bits are tapered?
Why?
Davefr
OR
They do #1-3 in a single pass
6PTsocket
True, if you are using taperd wood screws. They are becoming obsolete and being replaced by untapered wood screws in many applications.
skruft
Correct. If you want to use a traditional wood screw and have it go in easily without ruining the head, esp. one with a slotted flat head, you have to pre-drill three times or use one of those sets, and use a screwdriver that exactly matches the screw slot. Many people also put lubricant like wax on the threads. Without these precautions you can mar or destroy the slot, or the screw will not hold.
It is not actually necessary to use a tapered bit - some sets are made with straight ones. Usually these sets are made so that you can either countersink or counterbore just by going deeper.
I believe wood screws are not used much now except for fine woodworking and wooden boats, because they need too much time and care to drive a lot of them in commercial use. However some people believe only a slotted head is attractive when exposed on hinges and such.
jimreed2160
Tallahassee FL
True. Wood screws are both worthless and dangerous without a proper pilot. Worthless because of failure and rework. Dangerous because they can damage or even destroy your project piece.
The most common failure is stress cracking of the wood. Hardwood or softwood, most will crack eventually under the stress of an unpiloted screw. The second failure is at the head from over-torqueing. Either the head is deformed or broken. The third and most catastrophic failure is a broken shaft. This failure is most common on brass screws.
When I make repro furniture, I like to use brass screws for hinges as noted. The trouble is that most modern brass screws are made from cheap alloys and are exceedingly soft. I take special care drilling proper multistep pilots and then install exact sized steel woodscrews first. Then I remove the steel screws and install LUBRICATED brass screws. It works well MOST of the time.
dirt_dobber
Bee Cave, TX
Man - you are spot on! I wish I had not had to learn this the hard way.
