garagelogician
Previous owner (he's originally from Russia) built this shed 9 years ago. It was over the property line, so I jacked it up, set it on some pipes, and rolled it forward on the concrete apron...then cut off the back of the pad.
The siding was right down to the concrete, and moisture was wicking up through the OSB sheathing. The sill plate is treated, but he didn't have any sill seal, just a crappy caulking job. The concrete pad has a very rough broom finish, and is not very level. It is also a little low on the side pictured.
The shed is still sitting on the pipes, but I really need to get it fixed up and set back down...but I don't want the sheathing to rot out from continually getting wet.
I plan to remove about a foot of sod, and replace with mulch or crushed stone to keep the yard from draining on top of the pad. There are gutters (which need to be cleaned), so that should help as well.
Should I just put down some regular sill seal, caulk it and call it good? Or should I spring for the expensive sill seal that has the EPDM layer? Other ideas?
