cashishift
What should I be looking for?
GJ approved units?
GJ approved units?
General soldering, possibly light circuit board work. Mainly fixing stuff.
smaller gauge wire would be its primary use if i had to guess. occasional soldering of the end of 4ga wire for cars batteries.
LOL, you're not going to find one iron that can do all that.
That's like saying you want a sports car that can hold its own on the track, but sometimes you want it to haul sheets of plywood and the occasional pallet of rocks.
If you want something inexpensive, that can work on a circuit board and join wires perhaps as large as 16 gauge, I'd point you to this:
https://www.amazon.com/dp/B000VINMRO/?tag=atomicindus08-20
A soldering station has thermostatic heat control. It will heat up faster, and stay at the right temperature, which makes things so much easier.
The 937+ has a little more power (that's the one I have, though I'm not crazy about the digital control):
https://www.amazon.com/dp/B000I30QBW/?tag=atomicindus08-20
Both of these take Hakko tips.
For most other soldering, I use my Weller Portasol. Butane is cordless, so that's a plus, but heat control is a little more difficult with these, and it's easy to overheat the tip if you're not paying attention.
For battery cables I would use like the D650 or a similar sized soldering gun, a little iron won't do it...
Or if you had a propane torch that works too.
I did...but it was discontinued years ago.LOL, you're not going to find one iron that can do all that.
Battery cable is more a matter of a torch and a pot of hot, liquid lead, and dipping the prepared end. Otherwise you're going to melt the insulation before you get much solder applied.I'd say you need at least 2 soldering irons and a variety of tips for each, especially for circuit boards. I don't like soldering on battery cables but if that's what you want then that's a third.
I recommend getting a butane version as another tool to supplement your soldering abilities, I have the Master Appliance version and it has done countless jobs on trucks and trailers, saving a lot of hassle with trying to find cords and also working in places where there were none. A side benefit is the exhaust gas output is perfect for shrinking moisture-seal tubing.
I recently bought a Hakko FX888D and it kicks ***. It gets HOT really fast, and stays hot.
I had the pleasure of using a Metcal soldering station many years back. I was amazed at the thin little pencil and the seemingly supercharged amount of heat that could be flowed from that tip. Not like anything I've ever used before or since. Of course the amazing performance is quite costly and I've never been able to justify it for my small needs.
e
