Hey guys I just bought an sk hand tools set 94562 which is in metric to give to my first son when he grows up. I was wondering if anybody knew if sk offered a similar set in standard?
I do not believe they do
-# 4532 - 32pc 3/8" Drive 6 point Standard & Deep
3/8" Drive Pro Ratchet - 7.5"; 3/8" Drive Flex Handle - 9.5"; 3/8" Drive Extensions - 3", 12"; Universal Joint; 3/8" Drive 6 Point Standard Sockets - 1/4", 5/16", 3/8", 7/16", 1/2", 9/16", 5/8", 11/16", 3/4", 13/16", 7/8", 15/16", 1"; 3/8" Drive 6 Point Deep Sockets - 1/4", 5/16", 3/8", 7/16", 1/2", 9/16", 5/8", 11/16", 3/4", 13/16", 7/8", 15/16", 1"; 3/8" Drive 6 Point Spark Plug Socket - 5/8". Packaged in a molded plastic case.
You may want to obtain a catalog
SK TOOLS
SK Hand Tool 94562 - 62 Pc 1/4 and 3/8 in dr Std/Deep Metric Socket Set
Description:
62 piece set is made in the U.S.A., featuring SK's high polish SuperKrome finish, which protects the tools from the harsh working environments found in today's workplace. All sockets feature SK's SureGrip hex design, which drives the side of the fastener, not the corner, to avoid edge breakage which can occur on rusted or damaged fasteners when a traditional straight cornered hex tool is used.
Contents:
1/4 inch Drive - 4.5 inch Pro Ratchet; 2 inch and 6 inch Extensions; 3/8 inchF-1/4 inchM Drive Adapter; 5.5mm, 6mm, 7mm, 8mm, 9mm, 10mm, 11mm, 12mm, 13mm, 14mm, 15mm Deep Sockets; 4mm, 4.5mm, 5mm, 5.5mm, 6mm, 7mm, 8mm, 9mm, 10mm, 11mm, 12mm, 13mm, 14mm, 15mm, Standard Sockets; 3/8 inch Drive - Universal Joint; 7.5 inch Pro Ratchet; 3 inch and 6 inch Extensions; 6mm, 7mm, 8mm, 9mm, 10mm, 11mm, 12mm, 13mm, 14mm, 15mm, 16mm, 17mm, 18mm, 19mm, 20mm, 21mm, 22mm Standard Sockets; 8mm, 9mm, 10mm, 11mm, 12mm, 13mm, 14mm, 15mm, 16mm, 17mm, 18mm, 19mm Deep Sockets. Packaged in a molded plastic case.
