Clausing Drill Press Belt Length
shawhite
Call clausing 800.535.6553. They stock most parts for these drill press and are very helpful with any issue you have.
Todd.Brock
Cincinnati
Make sure you are sitting down if you call Clausing. I bought a toothed belt for my 1865( I think). I have my receipt at home. I will check and see if it has the length. I could try to measure it. I think the belt was the better part of 65 bucks
Edit. -mine is a 1688 model
Edit - scroll through this practical machinist post. I think it give some math formulas for calculating your belt.
http://www.practicalmachinist.com/v...clausing-1800-drill-press-info-needed-294501/
Dingleburry
Great white north in an igloo
(Large diameter *3.14/2)+ (small diameter *3.14 /2)+(center to center distance * 2)
Then subtract
For A belt 2"
For B belt 3"
For C belt 4"
Thats your length.
A belt is 1/2 Across the top
B belt is 21/32
C belt is 7/8
Add X after letter for ribbed belt (AX)
Part number Example = AX36
Heres a good easy guide using a different method. Dosent mention the subtract 2 or 3 or 4. Ill double check at work tomorrow on an actual belt system here
When your measuring a belt with a string you measure the OD and subtract the numbers above for actual part number. When your measuring with pulley diameters id assume its the same. (Subtract 2/3/4 etc.)
Dingleburry
Checked on an air make up at work.
21 inch center to center.
6inch pulley and 11inch pulley.
Uses a B belt.
Length from formula was 68.69. Say 69inches.
Belt thats on it is a BX66. So yes subtract those numbers above.
454ragtop
Carver, MA
Dingleburry
No need to subtract. I think the problem is you think a BX66 belt is 66" long, it's not, actually measures 69". https://www.grainger.com/product/6L...71951&ef_id=WR2W6AAABFwbM7Ay:20170529221051:s
Yes, but the OP is trying to find belt size from just pulleys.(i think? Anyhow he dosent have old belt) So from the formula, you need to subtract the above numbers for belt types from pulley sizes+center to center. To get your belt part number.
And the 69 will be OD of belt, i think the 66 is from the pitch diameter length. Depends how/where you measure.
