HI,
I've just bought a SJ-35 Sliding Bridge Jack for my Danmar D7 4-poster lift. I bought this jack as it was the only bridge jack that would (based on online dimensions) fit between the 'tracks' on my lift.
I had hoped to find a rolling jack, but couldn't find one narrow enough. However, I've found that even the SJ35 won't fit as intended - if it's set wide enough to slide along the ramps (as intended) it will catch on the tracks intended for a rolling jack. I've fixed this temporarily by fitting the extending sliders upside down, so it slides, but along the roller track.
So..I've decided to convert it to a rolling bridge jack. Browsing the web, it seems the best way would be to buy a wheel kit for a FC5412 Rotary Jack (see http://www.ebay.com/itm/261401838090. These fit inside a square section tube, and the springs compress when the jack is lifting a vehicle. In theory, I just find some square section, weld it in place and I'm done....
But...I need to know the distance from the top of these square section tubes to the track along which the rollers roll (this is to ensure that I'm not going to end up with the jack either hanging below the ramps, or too high to get my (very low) cars on the lift. I'd like to know this before buying the wheel kit (which isn't cheap...)
If anyone has a rotary bridge jack with these wheels, and can grab me some measurements I'd really appreciate it.
If I go ahead with this, I'll be sure to post details.
Thanks!
Steve
Thanks!
Steve
