Legacy Industrial DeltaDye and SEC sealer installation
Manganos
Virginia
This weekend I applied the Legacy Industrial DeltaDye (Mahogany color) and topped it off with two thin coats of the SEC sealer. Below you I will give you the steps I took and this evening I will post the pictures when I get back from the river house :beer:
1. I swept the bare concrete floor with a broom then I did it again...and again. The details are in the prepwork and I didn't want to have problems with the finished product due to being lazy.
2. I used sulfiric acid to etch the floor. It took 24 oz of the granular acid mixed in 2 gal of warm water. Make sure you use warm water to make sure the product disolves.
3. I used a shop vac to gather the left over water and small concrete particles left over from the acid etching. Then I used a leaf blower to make sure the floor was clean. Again the details are in the prepwork.
4. Using blue painters tape I went around the edge of my walls and around anything else touching the slab. (Wood stairs and garage sink as well as to have a demarcation line at the garage door)
5. After the floor is completly dry I poured the DeltaDye into a $5 garden sprayer from Home Depot. This is the only thing I had help with. My 17 year old son shook the dye for 10 minutes for me. I took my time applying the dye to ensure complete coverage but when the first coat dried I could see lines where I applied the dye. No big deal as this was the first coat. Legacy Industrial supplied me 3 gallons of dye which ended up being perfect for my use.
6. Man the dye dries really quick. As soon as I finished the last of the garage the first part was ready to be dyed again and I made sure to fill in a little heavier on the light areas. I repeated this again but instead of a misting action I used more of a stream and just stood back and shot it.
7. A little over an hour later I applied the first coat of SEC Sealer. I had 4 gallons of sealer for 575 sq ft of floor. I applied it with a 3/8" NAP roller attatched to a junk Home Depot extendable broom handle which I broke in the first 30 minutes.
While applying the sealer I got nervous because I was a little over half way done with the first coat when I noticed I was running out of my first batch of sealer. Then I noticed I still had product left in the can and another gallon from the first box!!!! I was able to get 80% of the floor done with the first gallon then mix up the second to complete the first application. That left me with a bunch of left over product from the first 2 gallons.
8. Be patient....... it was now close to 1200am and I was ready to apply the second coat but to be honest I should have waited another hour or so. I wore no shoes but an old pair of socks and it was still a bit tacky. I applied the second coat and had a bunch of product left over. It hurt to throw away that much sealer but after joking with Legacy Industrial over Instagram I decided to follow the directions (imagine that) :evil:
So what does it look like now? It looks great. I've already had people sneaking a peak and they want me to do their floor and even offered to pay me three times the cost of the material. Instead I told them where to buy it and that I would help them with the installation.
What is there to take away from this long post? PREP WORK IS THE MOST IMPORTANT and then FOLLOW THE DIRECTIONS.
Use a drill with a mixing paddle to make sure the sealer is well mixed and start early so you aren't up until 1am.
Pictures to be posted this evening......
Manganos
Virginia
First group of pics I have no clue how they got all turned around.
Manganos
Virginia
Finished product. It shows lighter because I had no lights on inside and this was with the door open and the window light coming through. With the lights on there is a nice variation in color as well as the shine from the sealer.
Chevyreb
Floor looks great!
How durable and long will this finish last and is it easy to touch up small areas. If when you did need to reapply the top coat down the road what type of prep would be required?
Manganos
Virginia
I'm about transparency so I will tell you this. I moved in a 500# Husky tool chest and I put light superficial scracthes on the sealer. I was going to wait until I had everything moved in and out , IE 36 Gun Safe, before I worried about fixing the small scratches. I believe you just wipe down with a solvent and reapply the SEC Sealer. Hopefully small quanities of sealant are available for touch up. I will follow that up with a floor wax to allow some extra protection. @legacyindustrial
Toomanytools?
Washington
Ok I'm confused, you said it was a Mahogany stain? Which I would think is in the dark or brown family, your floor looks like wet concrete. Not knocking it, just not what I thought it would look like. I'm looking to do similar I have 2000 sqft of garage that I would like some color ( light) to it then a sealer for the gas, oil ect spills.
Thanks
Jeff
Manganos
Virginia
It is a Mahogany and it is a very dark brown. It is exactly as I had envisioned. I believe Legacy also will sell you a sample amount to test. Keep in mind that the stain by itself looks way differnt when the sealer is applied.
Thanks
Jeff
LegacyIndustrial
deerfield, IL
Correct. You get 4 colors to try.
