I'm looking to get a cordless circular saw, and since I've already committed to the Makita LXT system I'm obviously looking at the Makita saws. Wondering if anyone has used the 36v 7.25 saw and if I should go with that over the 18v brushless 6.5 saw? Pros and cons of both saws?
In the same boat OP - just bought into the LXT system and would like a circular saw.
I've seen 5.5" thick Douglas Fir glulams cut with the 6.5"
brushed Dewalt saw. Obviously didn't get through in one pass or even four passes and had to finish the cut with a reciprocating saw but it handled it fine. The brushless Makita should be at least that good.
I don't want the rear handle arrangement of the newly released Makita X2 so I'll will decide between the two saws you're considering.
Despite the fact that I've done most of my cutting over the years with the typical right blade CS I think I'll get the 6.5" saw for convenient quick cuts and for better sight line of the blade.
Have you used both right and left blade saws?
I do like the sight line of a left blade saw but I have gotten used to how the wide part of the shoe of a right blade saw is supported by the "keep side" when making the typical cut. I also like a right blade for some overhead work and for cutting up against an edge guide.
I would focus more on that than blade size or total voltage. If you were unaware of the newly released X2 left blade saw it's basically the same setup of the typical worm drive saw.
