Is this tap in device any good?
Brian_WK
NE South Dakota
No experience with that one directly but my thoughts on any vampire clips are not good. I'm guessing this is low voltage application as I don't think they are allowed on 120V etc.
Brian
joe_padavano
Northern VA
No experience with that particular style, but it can't be worse than the blue Scotchloc taps. Those things should be outlawed.
disston
Silver Spring, Md
Low voltage only and not good in any situations where vibration will loosen the wires which is anywhere you find low voltage. Geee. :lol_hitti
Warrenator
Newberg, OR
Good for troubleshooting though, just look at a wiring job (usually trailer lights) with these on it and boom, there's your problem!
APEowner
Sunny, New Mexico
I don't like insulation displacing connectors on any mobile application or anything else that sees vibrations. The same sharp edges that cut the insulation will eventually work their way through the conductors. Every standards organization that deals with vehicles (SAE, FAA, ABYC...) specifies properly crimped connectors for wire termination in almost all instances.
Having said (or typed) all of that those look like really nice IDCs and I'd be curious to see how they hold up. I wouldn't use them in anything mission critical however.
APEowner
Sunny, New Mexico
Actually, low voltage is found in millions of industrial applications where there isn't any vibration. I still don't like IDCs though.
Tim65GT
I don't like them either, and it's hard to believe they are approved for use in RVs. I found three of them that are used to transition from the 14 ga SO type cable to NMC behind the slide trim behind the theater seating.
prostreetamx
Las Vegas
Model railroad guys use these a lot for tapping a larger gauge buss wire for smaller wire to solder to the track. I also do not like them and will not use them for any application. They are also called suitcase connectors and anything that cuts the main wire is not good in my book.
matt_i
SE Michigan
What I usually do is cut the main wire, use a panduit heat-shrink **** splice, and simply twist the two conductors together on one side before crimping it and then shrinking it. The splice has a weather-resisting adhesive that flows when the temp is right, which nicely fills the voids and also provides some strain-relief. Sometimes the splice has to be up-sized in diameter to accomodate the two conductors. I stock these sizes in my shop, a large number of them are in service on my trucks and trailer and I am happy with the performance without ever having an issue.
http://www.panduit.com/en/product/BSH18-Q
http://www.panduit.com/en/product/BSH14-Q
http://www.panduit.com/en/product/BSH10-E
