Ok is it me, or are they junk?
I have been told they only last a couple of seasons due to the bearing design. Gosh I can't imagine this would be true without a law suit.
So what would you do? (If I had money to throw, I would get a new furnace). The current inducer motor I switched out with 3 years ago (used unit) has a little shift play and had a small vibration. If I touch it with my finger or play with the rubber bushings, it goes away for a while. I do have the previous unit that I cleaned up the other day. It was making a "dragging" noise but I believe it was from all the drywall dust caked into it. I lubed the bearings and cleaned everything up. It spins freely now with no drag (spins for a long time) and no shaft play.
I was told that shaft play and vibration is normal on these from sources. Am I just picky on having items work perfectly?
Thoughts?
Thoughts?
