I googled these, there are more plans. If you could build a boat, you can build an oar.http://duckworksbbs.com/plans/storer/oar/index.htm
... it appears that there is plenty of room for the rower to lean back...
This is as close to what I have in mind for the front TB's.![]()
When I posted the picture of the boat, I was pointing out the design of the thigh brace. There will only be 1 person up front.
Those Pavarotti boats are pretty. I like some of their features, but i can't figure how they couldn't be heavy pigs.
Where did the name "nimrod" come from?
While looking for thigh brace images, I stumbled upon this pic. this is what I want to do with the front seat. Obviously, because I'm a cheap *******, the cooler will be the Walmart version.![]()
If at some point someone wants to put a motor on, the anchor bracket will have to be removed. If you think this might happen, consider that when building a bracket.Pretty simple to register a boat that is under 16'. This one is just about 15'. Even more simple if it has no motor. I'm not putting one on this boat. Don't know if the next owner will or not.
The advantage of low gunnels becomes apparent if you have to climb in and out of the boat often--eg low water, not enough to float the boat, so you have to drag it, hopefully not often. Also, if you are running a wild river--one that floods and changes course, sometimes you come around a blind corner which is different than the last float you made, to confront a tree across the river and have to bail out in a hurry. Ask me how I know. The disadvantage of the flared "dishpan" sides of my Wooldridge was the long step over the side. I learned to cope with it, you'll learn to cope with the idiosyncrasies of your boatPS
The sweetest driftboat I ever ran was a Shepcraft design built by Keith Steele in Portland, Oregon. Alas, not mine. Wooden boat with low gunnels ( I know,gunwhales). First time I ran it was on the Humptulips River. I thought I was doing pretty well, but, the owner, partner and friend. said, " you floated over every piece of fishable water".. I guess I did, but, I listened and learned.
That it is.Well, not there now. Your Hula Bay yacht Club was awesome!
Wood, composite, aluminum? That's a great price.
I do want try to fab everything I can with this boat project. If I fuq up my aluminum oar build, I'll contact your uncle.
Bit late to this party, but my uncle makes oars. A pair of 8'6" for your drift boat are just over $250USD. Shipping 'em costs another $50 or so.
http://www.barkleysoundoar.com/
He's a one-man shop so may not respond right away to calls/emails. The oars are amazing though, very light and strong.
Quickly fabbed up the oar blades. Still need to clean them up, but am happy how they turned out.
I'm quite surprised how light they are.
Thanks for the sketch, Paul.
Started on the trailer this morning. Tired of the drift boat taking up my lift space.
Picked up some aluminum pipe for the oars.
Every boat is a compromise.This is a great post. My buddies were just talking about trees over the steam.
I was instructed to not build the thigh brace higher than the top of the bow. If the bow passes the tree over the river, nothing else will stop the boat...as long as every one hits the deck.
Oddly enough, I just got into the house after cutting the parts for the boat trailer.
While in Florida, all I got was a ration of **** why I haven't finished the drift boat yet. My response was I could have got it done if wasn't down here blowing wad's of money. They shut up.
Do you think there is such of a thing as the perfect boat?
Sometimes the tree is a "sweeper" at or just below water level. Doesn't matter what level the thigh brace. Personally, I wouldn't put in a thigh brace until I figured out if and what kind I wanted. "Need"has not got a lot to do with it.This is a great post. My buddies were just talking about trees over the steam.
