That's going to leave a mark.
glider
Flint Michigan
We are in need of a new septic system. Today they started bringing in material. The leach field is about 400' from the house and tank. A duel chamber tank with a pump. What a mess this is going to be.
58Yeoman
Central IL
Is your purple martin house occupied? I've been trying for two years to get some to come to my house.
matt_i
SE Michigan
Personally I would go rent a sod cutter and put all family members and kids to rolling it up and storing it somewhere. Even if it dies off/goes dormant it will be better than trying to seed it later. This might be too late...I see the trucks are already running...
JoeFin
NorCal - where the Rednecks Race
Leech fields don't last forever - and especially if your doing a lot of clothes washing with bleach and harsh detergents.
I hope your contractor recommended a "Diversion Valve" so you can alternate between leech fields when its all done.
glentre
Gloucester, Virginia
Be very careful about trying to recover sod over a septic field since, especially in your case with a failing system. The ground and grass above is now contaminated with waste material from the toilets. Not a healthy thing to do.
Glen
jmarkwolf
Southeast Michigan
Our field was failing to drain adequately about 15 years after building our house.
We had a guy come in and claim a non-permiable "bio-matt" had developed and was preventing draining. He explained it's kind of like a layer of jello.
He poked a hole through the middle of the field with a pole, pulled out the pole, and there was an immediate and loud gurgling sound as the field tried to drain into that single little hole through the bio-matt.
He then sunk a hole with the pole on a 1-foot grid and blasted it with a big blast of compressed air (little geisers erupted from each previous hole), to disrupt the bio-matt. Afterwards he installed an aeration pump in the tank to oxygenate the waste, like the waste water treatment plant does.
It's been fine ever since, 10 years or better. Costed a fraction of a new field.
G
glider
Flint Michigan
I feel confident in the contractor and the system, location. With the blessing of the Health Department. I think I'm more bummed out about straightening out the mess.
EOC_Jason
Bentonville, AR
Yes, by adding that you now have aerobic bacteria (requires oxygen to survive) digesting the waste that is much, much, much more effective than the anaerobic bacteria (do not require oxygen to survive) found in classic septic systems.
With the aerobic digestion the grey water going out to fields or being pumped to sprinklers is more or less clear... They really are the way to go and if I ever have to do a septic again I would do an aerobic plant in a heartbeat.
