For what you are telling us that you want, a conventional split is what I recommend. It will be able to raise the temp quicker from your "base" temp, it will have superior filtration to the minisplit, you can a more even distribution of air with out fans (but with high ceilings, fan may be recommended), you may (depending on area) have better access to techs that are familiar with your equipment, equipment costs for replacement/repair are lower, and it can be programmed to not run the backup in certain situations to save some $$$. I would shop around though as I believe you can get a better price on a conventional split. I also would entertain branches off of the trunk in your layout to better distribute the air. It can be hugged to the ceiling or roof line.
