jrp458
Middle TN
That big drywall mud drill is useless. The power has been on in the house for at least 2 months by that time.
As a residential project manager I have never seen guys hang and finish without having to use a temp. power pole somewhere on the lot. You have one other trade on site that needs power, and that only gives you, at most, 2 outlets per trade.
How would the power to the house be on at this point in new construction? Electricians definitely haven't done their trim out, and more than likely you haven't gotten utilities ran to the house yet.
chrisexv6
CT
Interesting notes from that.
M12 Fuel gen2 hex impact has slighly more power 1300 in lbs, believe old one was 1200.
The 3 new lights, mini stick, headlamp and flashlight are a NEW battery platform not M12.... F that
Makes me wonder if Milwaukee "inherited" the Ryobi 4Tek format.
rmsg0040
Toronto
Don't know about you but I am very interested, in the video said 3.7V, 18650 battery maybe? Would need more info
Jamie V
Atco, NJ
Removable battery at that so you can still swap them out (just not as easily as the M series batteries)
rmsg0040
Toronto
M18 rover, rechargeable mini stick and headlamp, penlight, m12 ratchet is on my list, who knows what else
Jamie V
Atco, NJ
Just ordered the underhood light but on the list.
Soldering iron
Heat gun
3/8 ratchet
M12 impact
3/4" high torque
Stackable storage
DFB
Southern VT/Western Mass
Oh man the 2771-20 M18 transfer pump was absolutely flawless today and saved me lots of time walking down to river bank to pull start my gasoline B&S powered Pacer pump.
That pump is kind of limited by the suction line I have on it. A really nice 25 ft. piece of 1-1/4" wire reinforced hose I got from NT a long, long time ago. And it's a clear hose too so can easily see the water pickup moving when priming it.
So instead today I used a 50ft piece of good quality rubber hexagonal garden hose for the pickup line which brought the pump closer to job setup. And lift was like the 12 ft mentioned in a prior post. So I actually was able to set it right under my trailer hitch connection and all I had to do was walk over and push the switch on! :D
Output was thru another 100ft of the same hose...2 more pieces coupled together, and I was able to water all my plants not once but TWICE on a single 9.0 amp hr. battery charge. And I have plants covering four 20x20 ft. rental areas for like a total 1600 sq. ft. worth that I have to maintain.
Worked great and if the hose kinked the sound pitch would change so I quickly knew I had kink in the hose as I was moving and could straighten it out.
Anybody that did see it operate was impressed.
Milwaukee rules!
There was one bar left showing on the ride home. Plus I cycled the pump on and off more than several times to fill 2 gallon watering cans for spot watering jobs as I noticed what needed more attention as I was working all day and dang was it ever hot. so there was lot.
My landscape friend came by earlier in the day and I gave her the run down on the pump and she told me get her one!
So I will be looking for the BEST deal on one now and maybe several 9.0 batteries too. Though a series a 5.0 will work quite well and may not get as warm as the 9.0 did on continuous pumping. But will have to see about that.
Well tomorrow's another day of fun in sun. :wtf:
And have the 9.0 on the charger now.
dsimatt
I snagged a 7 1/4'' circular saw today at HD and the whole time I charged the 9ah battery it had a loud whine, is this normal?
dsimatt
A number of people, myself included, have had a whine noise coming from the rapid charger. No ill effects yet.
Thanks, I wasn't to worried just had it in the house and it pissed off the wife so there will be no charging it in the house.
fivespdcat
One of my rapid chargers whines the other doesn't. Performance is the same for both. I'm thinking about calling on the loud one.
Sent from my SM-G920T using Tapatalk
Buckgnarly
VT
Mine whines, but I prefer not to use it unless I need to charge quick.... which is not that often. Gets wicked hot too if charging multiple batteries in a row.
dsimatt
Are you talking the charger or battery, my other charger the came with the cheap drill set never made noise when charging.
Well I put one of my 2ah batteries on it and it wasn't as loud but still did it, my old charger is not a rapid charger so I'll stick with that one.
cajunfirehawk
Ms Gulf Coast
FWIW, put my new MIL string trimmer and free hedge trimmer to work yesterday, my 1st impressions:
  • string trimmer; about as heavy as my gas unit, built well, works well, used my 5.0 batt, no issues what so ever
  • hedge trimmer; blade is longer than my echo gas trimmer and again, its heavy, built well, works well, again used another 5.o batt pack only one quirk that may or may not be an issue down stream, the "both sides" safety switch you have to push every time you want to engage the blade, hoping this isn't a week point in the future?
Pleased with my purchase. :beer:
Buckgnarly
VT
Charger, blows off some hot air and gets warm. Batteries never really got warm.
JBA
Same experience here too. I have three of the rapid chargers and three 9.0Ah M18 batteries now. All three rapid chargers make the same "screeching" sound. They are relatively quiet when they first start charging, but get noisy as they get warm. If starting with a completely discharged 9.0 Ah battery they get really hot, and even smell a bit, before charging is complete.
I haven't yet, but I may try a standard M18 charger next time a 9.0 Ah needs a charge. It will take much longer but should work. Does anyone know it the rapid charger is noisy if charging a 4.0 or 5.0 Ah battery?
deberly12
Lebanon County, PA
I might consider a chainsaw. I dapple into tree work. A small (10in) cordless would be nice for climbing. As long as it isn't designed as a home owner saw. I have a Craftsman C3 one but it is so weak it is faster to get out the Husky even for a quick cut. Please put features in it like chain brake and automatic chain oiler.
Sent from my XT1635-01 using Tapatalk
Ign
Butte Peak ND
The Ryobi 40V is brushless w a 14" bar and oiler. No brake but I've never wished for it (and yeah I've used plenty of gas saws). The Ryobi is kinda heavy though.
If Milwaukee releases one I promise you it'll be 14" minimum and likely 16" to compete w Echo's 58V unit
DFB
Seems there are actually a lot of battery powered cordless units on the market already today.
Some big name brands offer at least one option of more professional grade of cordless saw such as Husky and Sthil , as does Echo and they are usually much more expensive than the cordless stuff like Home Depot sells.
Then the other names...EGO, Greenworks, Sunjoe, Oregon.
I'll bet some are rebrands too like the Wen, Toro, Scotts and Earthwise units.
Of course then there are major tool brand names like Ryobi, Dewalt and Makita they all already offer cordless battery chainsaws.
That's not way an all inclusive list I'm sure there are some others too.
I have been after my boss for several years now to get some cordless units for tree pruning in orchard but he is not sold on them yet. Instead the guys (mostly unskilled labor) are always messing around trying to pull start gasoline saws that nobody ever maintains properly IMO what a waste time and manpower :D
I have had two Echo premix gasoline saws of my own for years and they have been pretty flawless in operation over all that time. We have mix of Sthil, Echo's and Jonsered at work.
Trey T
Houston, TX
EU model for M18 8.5" (216mm) miter saw w/ fixed sliding rails.
US model for M18 7.25" miter saw w/ the old moving sliding rails. :mad::dunno:
so disappointing!!!!! I wonder why we gotta have the crappy version - patent issue?
DFB
I like the looks of the EU model reminds me more of my 7 1/2" craftsman radial arm miter saw
And the US version more like my Ryobi miter saw (chop box)
Chris_the_wrench
Chinook Pass
The Milwaukee addiction thread!
A quick reply to my own post. I got the 18v fuel polisher and 18v fuel grinder. I used them to prep my deck and I was very happy with how they worked. Running the polisher with the Osborn brush allows 20'ish minutes of near constant runtime. Since all the work was overhead I was in need of a break every 30-45 minutes so 2 batteries worked out ok. When it comes time to do the house I'll need a couple more batteries to keep up.
The grinder has been one of those 'wtf have I been doing all this time' moments. No more dragging 400' of power cables or dragging the generator to the some part of the farm to grind some bolts of a fence or similar work.
Only issue is now I 'need' the circular saw and sawzall. Today I had my fuel drill/driver/grinder out fixing some wood bins, but I was still cutting 2x's and plywood with a chainsaw!
-Chris
Howdy
I just made the switch to the Milwaukee 18v platform. I picked up the fuel drill/driver a couple weeks ago when Homedepot had them on sale. WOW. So much better than the 18v rigid I was using.
Anyways I need a variable speed polisher to run a 6" and maybe a 4" Osborn brush for some wood finishing on my house/deck. It's used to surface the wood after stripping with chemical/pressure washer to prepare the wood for a fresh stain/sealant and knock down any fuzz.
Are any of you guys using the Milwaukee M18 Fuel Polisher? If so how's it working for you vs a corded version you may have used? If anyone is using it for wood finishing I'd really like to hear your experiences. I'm abit concerned about run time and power. I can't find any horsepower or other power numbers for the 18v product to compare vs the corded versions.
Thanks
-Chris
PearlWhiteGT
South Texas
Purchased this M18 Fuel Rotary Drill for my dad not too long ago but he doesn't really have any use for it. I don't own any M18 stuff so looks like it will be going up for sale or would possibly trade for some M12 Fuel stuff.
