Terrick down Under
Ahhh, you gotta love concrete and steel!
Good work on the repairs, as usual!
Hey Bob, nice repair of the termite damage.
Still here and watching you Bob. I can't let Andy be the spokesman for the group.(Although he's probably the one I'd for if we needed one)
Another fine repair made by the one armed bandit.![]()
Mark, Dan and Terrick, once I removed the damaged double 2"x12" header I decided to open up the wall below the window. I figure I need to buy a whole 4'x8' sheet of drywall and I'll feel better knowing it's clear of the little buggers.Good work on the repairs, as usual!
Terrick, if I was a few decades younger I would begin digging the footings for a half-buried home similar to yours. Several homes on our street have basements, which is unheard of in South Florida. If our place collapses in a hurricane, we'll probably get a couple of shipping containers bolted to the slab.Ahhh, you gotta love concrete and steel!
, he finally took it back.
He Slim, thanks for stopping by and thanks for the compliments. I did have the termite guy hose the exposed wood with termaticide.+1 for the nice repair on the termite damage. The new treated wood header ought to keep the buggers at bay. Can you paint the rest of that wall cavity with some wood preservative to protect the untreated wood?
We don't have termites up here where it gets -40 but the ants still get in where they're not supposed to. I had to cut part of my concrete front step out of a previous home I owned. They had started eating out the end of one of the floor joists. Definitely not a fun project.
I also have to do some work on my driveway again this year. The ants are working overtime excavating the base under the asphalt.
Kitchen remodel sounds good too!![]()
Cheers!
Thank you Steve!Bob, well done![]()
Aaron, I appreciate the visit and I'm hoping to at least win this battle.Looking good Bob. I'm sure you will beat these termites.
Mark, unfortunately I grew up using wood to build stuff. I didn't get a welder until I was in my 60s.Apart from the fact that termites think that anything larger than a toothpick is fine dining, it's often quite a challenge to find a straight board.
Good thinking Bob - the longer screws did the trick.
I know that a lot of folks on GJ are big fans of wood, and I can definitely see the beauty of a piece of fine furniture, etc. - but give me steel to work with any day.
Very true Terrick, but folks with the skills I lack can fix a short piece of wood...Yeah, and if you accidently cut the steel short, just weld it back and cut the right size!
Mark, my motto is "measure five times and keep cutting 'til it fits."Hey Terrick, I'm glad to hear that I'm not the only one who has done that.![]()
Stewart, this is actually the first time I've used the Kreg tool. I used the Harbor Freight version first. I did think about putting some marks on the beam. If someone ever has to take this down, they need to know the pocket screws are S02 square head, the screws attaching the plywood spacer are T-25 torx head, the screws holding the two beams together are #2 phillips and the bolts on the outside are 1/2" hex. I hope I have room for all that information.Stop screwing around! Lol.
The pocket screws are a lot better idea than trying to toe nail them. Looking good. You should carve y'alls initials inside a heart with the year before covering it up.
Andy you do need the Kreg pocket screw tool. Makes a great joint.
Bobby, I appreciate you stopping by and commenting. I like that idea! I don't even need a permit to open carry a moisture meter. The pins are sharp enough to inflict a decent amount of pain but nothing fatal. I'm gonna tell my wife that's a Taser and I won't be real surprised if it wakes me up the night after I forget an important anniversary (honey, of course I remember you wore those shoes on our third date -- it just slipped my mind).Bob repair looks good and I bet you could carry that moisture tester and tell the bad guys it was a stun gun and get away with it. Or maybe just test your skin to see if you are working up a nervous sweat and need to get out of Dodge.![]()
Terrick, that joint is fairly common over here. Not only in construction but it is also the same joint (made to a higher standard) for the keel of wooden ships.BH, if you have a wood joint like that there is no way you should ever cover it up. That is a piece of art.
Morning Bob,
Good woodworking mate, if the timbers ever need changing at least you can now just unscrew them.Hurricane straps? don't need them here, tbh, they look pretty small compared to the size of a hurricane.
I can't agree with BBChevro, wood all day over steel, it pays my bills.and that scarf joint is a thing of beauty.
Regards
Steve.
Isn't it amazing what a little bit of steel can do to maintain the integrity of a building in high winds. I'm sure those are placed regularly around the perimeter of the building.
Terrick, I completely agree.BH, if you have a wood joint like that there is no way you should ever cover it up. That is a piece of art.
Andrew, my Viking heritage helps me appreciate the joinery but I didn’t inherit any of the skills. My joinery looks like a failed Cub Scout project.Terrick, that joint is fairly common over here. Not only in construction but it is also the same joint (made to a higher standard) for the keel of wooden ships.
Sent from my SM-G900T using Tapatalk
Stewart, I guess I have to post a tour of the shop. It’s going to be “Andy’s Other Brother Cleaning His Shop.” It’s going to take me some time to prepare my excuses.Shop? I don't recall a tour of the shop.
Repair is looking good. Hurricane strap? We don't need no stinkin' hurricane straps.
I guess all of Florida got a bath today.
Hi Steve! The house was built in 1988 and that untreated header beam made it this far. If it and I last another 29 years, I’ll be 101 and probably won’t remember how to use a screwdriver.Morning Bob,
Regards
Steve.
Dan, my preferred method of pest control is drowning [see Bob Jr. story]. The termite nest was too far above the high water mark so I had to improvise."Then it started raining. I don't want to do electrical in the rain and I don't want to be handling drywall in the rain so I have to wait for it to stop raining. It started raining Saturday and hasn't stopped. Our pool is at defcon-1 but I'm not going to drain it right away. The ants living under the pool patio will drown when the water reaches the top of the tile. I'll drop it 4 inches tomorrow morning so the skimmer can clear the floating carnage."
Absolutely brilliant way for pest control.![]()
Andy, you’re right about the regular placement but it isn’t the belt and suspender solution the new building code calls for. Now each truss is supposed to be attached with a U-strap over the truss and down to the stud wall. Mine is just rafter clips but at least they have 6 nails attaching each one.Isn't it amazing what a little bit of steel can do to maintain the integrity of a building in high winds. I'm sure those are placed regularly around the perimeter of the building.
Stewart, you are so right. A few years after Hurricane Andrew our friends added a second story to their Ft. Lauderdale waterfront home. Before they covered the framing I had a tour. Asked my friend if he planned to use his cell phone up there because there was more metal than wood at the junctions of everything.Andy, we have more hurricane straps and clips than a **********. I'm beginning to wonder if they are to the point of being self defeating with all the nails penetrating the wood. We've never had a Hurricane Andrews in Tallahassee but we do have 100 yr old houses with no hurricane straps that have survived.
Steve, most of the time trailer (caravan) parks suffer the most damage. In addition, the most serious damage is the path of or close to the eye of the hurricane. Andrew's eye was like a huge tornado, destroying 63,000 homes as it passed through South Florida. It made another 40,000 homes uninhabitable. I've been through quite a few hurricanes with modest damage and have been able to do all but the roof repairs myself. My hurricane damage insurance deductible is $13,995 so it's expected but it's surprising how quickly repairs can exceed that amount.I do hope so, I did think that there would be more than two tying the roof down .
All we ever get to see here, on the news, is the devastation left behind, of rows of houses skittled along a corridor of devastation. God willing ,may you never have them put to the test.
Regards
Steve.
Steve, I sorta asked for that deductible. Any time you file a claim, it changes your "risk" rating and results in higher rates -- for years. I carry $1,000 deductible on my cars because I'd rather pay for a small dent once. When Hurricane Wilma tore up our screened enclosure I requested a repair estimate. The entire enclosure had to be torn down and replaced with a code-compliant one for about $30,000. As a grand-fathered repair and doing the work myself, materials (new door, aluminum flashing, square and rectangular aluminum tubing for the 22-foot frame) cost $320. I re-screened the walls and had a crew replace the vaulted ceiling panels for another $900.Thanks Bob,
Wow, £14K deductibleeye watering.Our house excess, as it is called here, £350, parts of our place date back to 1788ish, more likely 1817ish
I wiki'd your area and it's beautiful, I liked the name of the T-Rex centre, do you know it.
Regards
Steve.
JC, you are a smart man. I don't think amputation affects your mind but the blows to my head may have damaged my sense of priorities.Bob that repair looks great I have 2 arms and a little younger and I would have been seeking someone to do that for me.
As for the rain we haven't seen much of the sun in 5 days now. There are a lot of low lakes around me and being on a well I welcome it
Gee, around the pool came up a treat. It would be hard to not just sit and ponder in the sun.
Vladimir, thank you so much. I visit your amazing little garage every time your thread shows up on my subscribed list.Bob is very nice to look at your work. I like what you're doing. This is great!![]()
Steve, you are very welcome and kind. Over the 20 years I worked for IBM in Boca Raton, I only spent about 3 of those years on the main site. The Information Development (technical writers, editors and illustrators) organization was easy to move because we didn't need to be close to the mainframes or factory floor. Worked in a warehouse, converted supermarket and a bunch of rented office buildings. My best office was a big second floor all glass corner overlooking a golf course in the building where the PC was born -- sadly the work keeps you from enjoying the view (but it sure impressed my visitors).Hi Bob,
Thanks for the in-depth reply, you're a good man.
I thought you would know the T-Rex Centre, I've read ALOT of your thread.
Thats a great repair to the pool screen,lucky that's all you lost?, lovely tiles also.Travertine is very popular here, kitchens/bathrooms etc .
Steve.
Terrick, we don't spend nearly enough time out on the patio or in the pool. The white upholstery on the furniture is covered to keep it clean, in the event someone who needs to be impressed should stop by. Were I to pull the covers off and spill coffee, it likely would cost me another body part.Gee, around the pool came up a treat. It would be hard to not just sit and ponder in the sun.
Greg, you will be welcomed with open arms and uncovered furniture. My speedos are far too confining so I hope it won't be a problem if I don't wear mine.Yeh, Bob doesn't know it yet but I've already packed my speedos and plan to drop in with a case of (of course... Aussie, the real thing... ) beers to do just that...
Yep... really looks like a great space to catch some z's even WITH a hurricane blowing !!
, <snip>
